Accumulator Sphere change on a V6 Xantia.
Quackers
- x 17
After my last failed attempt to get to the presure release screw (the V6 is akward to work on!) i now have a modified spanner to try and reach it tonight. Next thing is i was told to put the O rubber ring in first then screw the sphere in, which is fine on a normal Xantia, but on the V6 it drops down like a lightbulb in a sealing light would. So if i put the O ring in first it will fall out, so am i just going to have to hope it does not knacker the O ring putting it on the sphere then screwing it in?
- x 1432
- x 1237
Stempy
When I did mine I just put the new seal on the block and it stayed there fine, no need for any grease or such like.
Lexia ponce
Lexia ponce
- x 1237
