Whoopsie daisy.
Well if its one thing I know, its my computer technical talk
One Question: The information I supplied, was it indeed correct?
Suspension fault
- (Donor 2021)
- x 39
- (Donor 2021)
- x 39
- x 666
You've got me wondering now.....jgra1 wrote:on second thoughts ...
I am going to rebuild as you say Simon, just re-read your post.. all makes much more sense now..
sorry for doubting 8)
will buy you a beer if i make it over there later this year
I wish I'd taken pictures when I stripped mine apart a few months ago I will when I do the other one...
I've never found a diagram for a Xantia height corrector yet, but the following diagram is from a CX manual:
So it looks like I remember wrong, sorry about that
On the other hand I'm sure I remember the two springs were spiral wound (different diameter at each end) so that they could compress to the thickness of a single spiral, but that diagram shows a normal single diameter spring with adjacent coils..... maybe I'm just going crazy....
Regards,
- (Donor 2021)
- x 39
Hi Simon,
hmmm a few things...,
I would be a little suprised if i had built it wrong, i was careful to keep everything in order..
Yes the spring has different diameters for each end.. but the larger diameter is a pefect fit for the convex shape of the brass coloured Diapragm plate.. (if you know what i mean)
I guess having the springs on the outside would still encourage centering..
yes they're shape does allow for fairly complete collapse, not a perfect one tho.. as you say down to a spring width, what effect will this have on metal disc sealing...? (if the springs inside the metal discs)
where is Anders gone, he must know this..
Hi there,i hope this helps,.Rear height corrector problems are caused by one of two things or sometimes both.The cradel it lives in, siezes up due to rust build up, or the spool valve in the height corrector itself gets stuck due to gunge or being bent when forced to move.The units themselves are not greased or lubricated when first fitted to the car so all of them go wrong in the end.The best way to sort the job out is to spend about £60.00 at pleiades and just bolt the complete unit (fully lubricated already) to the vehicle and its job done.
If you are still dead set on re-building the unit itself the order is-
Looking at the height corrector with the return pipe and two 3.5 holes facing you.
Left side (starting from outside)-DUST COVER, 8MM NUT, BRASS COLOUR PLATE, DIAPHRAM, METAL PLATE (DOMED SIDE POINTING INWARDS),SPRING (LARGE END TO DOMED METAL PLATE SMALL END TO INNER SHIM) , CIRCLIP, SHIM.
Right side (starting from outside)-DUST COVER, THIN 8MM NUT, FORK END, WASHER, BRASS COLOUR PLATE, DIAPHRAM, METAL PLATE (DOMED SIDE POINTING INWARDS), SPRING (LARGE END TO DOMED METAL PLATE SMALL END TO INNER SHIM), CIRCLIP, SHIM.
After you have re-assembled check the left to right movement of the spool valve if this is tight ,fix it with a new one.
These units are very hard to free up long term good luck anyway!
Suspension problems
Suspension problems
- (Donor 2021)
- x 39
- x 666
I have to take issue with this comment - height correctors don't need special greasing or lubricating because they are fully self-lubricating, and are designed that way on purpose.dirk diggler wrote:The units themselves are not greased or lubricated when first fitted to the car so all of them go wrong in the end.
Even if you fit one completely dry (after stripping and cleaning for example) the bellows at each end are completely full of oil due to natural leakage within less than a day of operation.
The entire insides including all sliding surfaces are submerged in oil at all times.
Also I don't agree that "all of them go wrong in the end" - if you don't keep the LHM clean they certainly can get gunged up and eventually start to "seize up" but in reality all that has happened is the micro holes in the dashpot damper chambers (which are about the size of a human hair) are clogged with gunge blocking the oil flow through the dampers.
Give it a good clean out and its as good as new. As long as the LHM is changed on a regular schedule to keep the oil clean there is no inevitability to this problem occuring...
Regards,
- x 19
height corrector
Sorry, i was talking about the cradel not being lubricated!
