Xsara Electrical Gremlins
Swervin_Mervin
Unread post by Swervin_Mervin »
Hi all. We have a '98 VTS that is flickering the oil, stop and coolant warning light and the coolant guage is going haywire. It all happens under braking.
A quick assessment of the Haynes' wiring diagrams shows all, including the tail lights are common to each other through Fuse no.12. Does anyone know what I should be looking for in terms of potential solutions?
They don't appear to share a common earth btw.
PowerLee
Unread post by PowerLee »
You sure theres not a lose earth screw on the back of the cluster?
One of the small screws that hold the plastic pcb to the back of the cluster & also used as an earth connection, Same thing happens to 406s & is a well known fault :wink:
Swervin_Mervin
Thanks for the tip Lee. Only had a quick check of all the levels in the dark last night. Will check that out later. I assume that's a dash out job?
Stuart McB
Unread post by Stuart McB »
I'm thinking the wire on the block to the oil temp sender. The MK 1's had this tiny thin brittle stuff that can break easily. Front of the block I think.
The wifes got a C4 I've got a ZX TD SX!!!!
Swervin_Mervin
Right, still not had a lookf but just been told that eh headlight warning buzzer is going off. This also runs off fuse 12.
Is getting to this pcb a dash out job?
