Is this terminal?
rory_perrett
Is this terminal?
My beloved Xantia 2.1TD Exclusive is not well. Citroen electrical gremlins stuck yesterday meaning the cooling fans didn’t come on while stuck in traffic. Water temp hit 120 deg and the oil temp probably that and a bit more. Seemed OK once on the move and the temps came down. However afetr it had been standing for a few hours all does not seem well.
The symptoms are
– sounds really clattery, very dieselly, like an old transit van.
– Its down on power, particularly noticeable on hills when it won’t pull as normal especially from low revs, better once the range at which the turbo comes in , will maintain 70mph on motorway
– Significant black smoke out of the back, seems to be especially when under load and at lower revs 1500 – 2000rpm.
– No water loss, no obvious emulsion in oil
– Seems to be running slightly hotter, particularly the oil temp, only a few deg.
Any suggestions guys?
The symptoms are
Dave Burns
rory_perrett
- x 1238
The usual problem with XUD engines overheating is failure of the head gasket or the head itself, but the 2.1 has a completely redesigned head with the main aim of improving the cooling efficiency and I havn't heard of one that has failed yet! So thats the good news.
If its not blowing water out of the overflow or has water in the oil or oil in the water the head should be OK. I believe yours is ECU controlled, I have only had experience with it in the XM and they have all had mechanical injection.
If it does have an ECU it could be as Dave says a sensor thats packed up. If its mechanical it sounds like a timing problem, is it possible that the cam belt has slipped a tooth under the very hot conditions
Ian Fearn
rory_perrett
Well if nothing else I'm feeling a bit happier.
It is ECU/ fly by wire so I was kind of hoping it might be a sensor. The engine systems warning light is not on on the dash.
The timing being slightly out could explain why it sounds more dieselly and the black smoke suggests over fueling which again could be the result of a confused ECU.
So do I go to a diesel specialist or is it a trip to a Citroen dealer so they can plug in their diagnostic kit?
deian
rory_perrett
Yep! Got one of the fans working already but I suspect the other needs a bit of a rewire. The fault is with the 3 relays that sit between the 2 fans. The 2 realys that are for the fans (I assume the other switches them between series and parallel to give the different speeds) and the holders they plug into just do not appear to me up to the job. There are clear signs of overheating (deformed and melted plastic and blackened contacts).
Not sure how long they haven't been working as the car rarely spends any time in traffic.
Check yours still work before summer.
deian
aye mine definately work, i changed the coolant last weekend and the big test was seeing if the fans stabilise the car, and they came on no problem, so i'm all set for the summer now,
it's horrible having a car overheat, it happened to my old escort on a hot summers day on a motorway, i was NOT impressed, thankfully i was in a motorway works area and i got a free breakdown towtruck, and they guy was nice enough to jump my fan connections, and wire a switch through the window so i can swith it on if it goes too high, 8)
NiSk
AndersDK
I've had a look on Citroen PR-net on the XUD11TE on the thermostat housing carrying the fuel filter.
Apparantly there are a few options for sensor fittings according to a/c or not and some other options I'm not familiar with.
But 3 sensors are possible to be fitted to the thermostat housing :
1 by itself (inwards towards engine) - and/or 2 side by side on the other side of the filter housing.
One sensor should be blue. This would be a 2-pole temp sensor.
Check it out by unplugging it - and then shortcircuit the plug (on the cable). This will signal the ECU that the engine is hot. And then the diesel engine clatter should clearly calm down as the ECU corrects the injection timing from cold to hot running condition.
If this checks positive - then the blue sensor is defective (disrupted). its only some $15'ish from your dealer.
Anders (DK) - '90 BX16Image
Richard Gallagher
Take a look at the following link for info on how the relays are wired. Whilst its listed as for a Pug 306, Xantia fans are the same. www.peugeotlogic.com/workshop/base/workshop.htm
Then at the top of the screen click on electrical, then to the left, 306 cooling fans basic principal of operation.
Berlingo Multispace 05 1.6 HDI
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
Picasso 02 HDI SX
Xantia 97 TD VSX
Xantia 96 Activa
rory_perrett
Thanks one an all.
Nisk - disconnected batter for 5 mins, unfortunately didn't do the trick.
Richard - that's is a really useful link
Anders - I've got aircon, if I remember rightly there is a blue and and a brown connector obvious on the top of the thermostat housing . The brown is the biton (or some similar name). Will have a go at shorting out the blue on later.
rory_perrett
Clogzz
- x 40
If it gets hot, pull the wire off the brown sensor.
That will send whatever working fan to the high speed.
Stories here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=18871
http://www.frenchcarforum.co.uk/forum/v ... hp?t=18965
http://www.frenchcarforum.co.uk/forum/v ... hp?t=17012
Stories here:
2002 C5 2.0i AL4 239,000 km 76372389
