Xantia 1.9TD relay
EDD
Xantia 1.9TD relay
Unread post by EDD »
There is a green relay under the ABS control unit cover(nearside of the engine bay) which is mounted on a bracket does anyone know what it's for?
EDD
vanny
Unread post by vanny »
does it go into a red connector?? Sounds like it might be the post heat relay as found on the 1.9TD engine
blueboy2001
Unread post by blueboy2001 »
Rather surprisingly it's for the ABS! I am assuming you are talking about a Xantia here. If you look closely at it, you will notice it has both Citroen and ATE markings on it.
Citroen Part Number 96131693, £15.50 + VAT
