Radiator
teethgrinder
Radiator
Evening...
I posted this in the Peugeot forum.
Does anyone know which Citroen/Peugeot radiators are compatible with a 1993 405 TD with aircon?
Mine has started to leak, and I don't want to fork out hundreds on a new one as it'll be more than the car is worth.
Thanks,
Robin
Thanks,
Robin
oscarloco
Re: Radiator
Hi Robin. One question, is the rad leaking from one of the tanks or from the core? It its from the core, change it. It its from the tanks, they usually can be replaced.teethgrinder wrote:Evening...
Thanks,
Robin
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
teethgrinder
Dave Burns
I don't know what others might fit but you really need to restrict the hunt to rads from indirect injection diesels such as the one that you own, meaning that one from a diesel 306, 406, zx or xantia might go in.
The reason for saying that is because these diesels loose more heat to the cooling system than any petrol or direct injection diesel engine, so they need to be more efficient and thus are often much larger.
If you don't like spending money on cars (or more to the point if your missus don't like you spending money on cars) you really don't want a xantia, They can be a potential money pit, and having said that I'd best go and find my asbestos boiler suit
Dave
Dave
citroenxm
- Fallen Hero
- x 70
- x 1240
citroenxm
- Fallen Hero
- x 70
- x 1240
vanny
mezuk04
Is a Xantia a money pit?????
If your thinking of taking a radiator off at the scrappers I personally wouldnt...the time took to get it out and then no assurances as to how long its going to last or even if its already leaking I would just spend the £100 which was for my Xantia and get the thing done yourself with piece of mind.
Volkswagen Golf 59' 1.6TD S
teethgrinder
I'd love to be able to afford to spend a ton on it, let alone be allowed to!
At the moment, there's not too much of a leak, and after a run there's no pressure in the radiator...is this a bad sign?
As it will have to come off, I might have a go with good old 'Chemical Metal' or whatever the newest fancy equivalent is.
Once the rad is fixed, new front pipe and centre pipe are needed, too. Grrr!
Robin
Robin
Kowalski
My Xantia is a money pit, I spend quite a bit of money on it. I fill the fuel tank up and it just empties it again!
As for servicing costs, the hydraulics have cost next to nothing, I've replaced spheres and changed the LHM but I've saved money on shocks and springs. I've yet to see a shock absorber that lasts as long as a Citroen hydraulic strut and steel springs rust then the car gets saggy they don't last forever do they? Cars with PAS have a hydraulic pump and cars with conventional brakes need their brake fluid changing. Vegetable based brake fluid absorbs water and that makes the calipers rust and leak, have you noticed how long lasting hydraulic Citroen's brake calipers are?
mezuk04
I havent spent a lot in the 6 months I got her.
Radiator at £105 which was taken out of the final sale price so i dont count that 8)
I purchased 2 tyres which I dont count since (forget the term) these are things that you are 'using' so to speak....if anyone knows the term shout it out
LHM change about £30
Glow plugs at about £20
5 spheres in total
Cambelt and water pump - which is something like the tyres, you do it more for the piece of mind if you like rather than because the car is a money pit....talk about justifying
and 5k services...thats actually about it
Where as the Zx had a lot more work done to it but all work done by ourselves which was still pretty cheap going....Took my sis home yesterday and saw my Xantia, it was an emotional moment
5 spheres in total
fastandfurryous
- x 4
Consumeables.mezuk04 wrote:I purchased 2 tyres which I dont count since (forget the term) these are things that you are 'using' so to speak....if anyone knows the term shout it out![]()
Which is all I've ever had to buy for my 405TD....
There are actually very few cars that are massively more expensive to maintain than others, it's more a case of how well it's been maintained in the past as to how much it will cost to maintain now.
This is not a signature.
f00lzz
Thats been my experience as well.... my TD was obviously poorly maintained (see previous posts) and subsequently I have spent loads getting it right...whereas my V6 hasn't missed a beat (touch wood).fastandfurryous wrote:[ it's more a case of how well it's been maintained in the past as to how much it will cost to maintain now.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
