I'm after a Turbo D Xantia to run along side my guzzler, the Activa Xantia.
I saw one today, looked nice, R Reg, SX, Aircon, but it had 160.000 miles on the clock. I just had visions of the clutch going. My friends Xantia Turbo D clutch went at 166,000 miles, and my SX 2.0i Petrol Xantia clutch on my old car went at 156,000 miles.
If it was not for that i would have bought it, do you think i was wise? It had no service history and high milage hence £450.
Is there anyway to tell if the clutch is on its way out? Also i have never had a Turbo D before, anything else to look out for when buying one?
Xantia Mileage
AndersDK
The obvious : the clutch slipping when you floor the pedal at medium rpm (2200 +) in high gear. This is the friction plate worn out or contaminated with oil for longish.
The mystery heavy clutch pedal : pedal is generally heavy and sometimes has a "heavier point" to overcome. The release bearing has grooved into the finger springs and will soon break through = pedal bottoms out no clutch function.
The pedal height over the carpetting has nothing to do with this. This can be adjusted at the clutch end - or in case of auto adjust cable - cable be replaced. Note the clutch pedal is (should be) considerable higher than the 2 other pedals. Must be at some 140mm above carpets.
Look for any service history. Clutch may already have been replaced
Anders (DK) - '90 BX16Image
OnlineRichardW
- x 1463
The Xantia TD clutch is an oddity, because it is a pull type. If worn it will tend to come in right at the top of the travel, and be heavy - obviously if really worn it may slip.... be cautious of anything that has a clutch pedal that is intially easy, then heavy, coming in near the top of the heavy part - the cable has been adjusted to take the biting point away from the top of the travel.
The other main weak points are headgaskets and heater matricies.
joelataxi
Re: Xantia Mileage
be cheeky and offer £400 for it, even if you do end up having a clutch and you kept it for a year then weighed it in, it would be less than £15 a week........................bargainQuackers wrote:I'm after a Turbo D Xantia to run along side my guzzler, the Activa Xantia.
Current Xantias
1996 LX 1.8 16v ..........breaking
1999 HDI 110 exclusive 206k + counting
2000 HDI 110 LX 86K
2000 Dual fuel 1.8i 16v 188k....resting
1997 vsx 1.9td estate 147k
2000 HDI 110 LX 86K
- x 1240
paulbx
clutch test
A test for a slipping or soom to be slipping (worn out ) clutch is:
1. park the car with plenty of sapce to car in front
2. Push the clutch down and put the car in 4th
3. Put teh seat belt on (you might bang your head on the windscreen)
4. Pick up the clutch and depress the accelerator as if you were taking off normally in 1st
Results
a) Car violently shudders and quickly stalls - good clutch
b) Car slowly and gracefull stalls - bad clutch
PaulB
Results
PaulB
Broomie(paulB) Xantia Hdi 90 estate
Kowalski
Re: clutch test
If you do this, be careful about how much accelarator you use, and how sharply to release the clutch. If you are too heavy handed you will break something, gearbox and clutch are most likely.paulbx wrote:A test for a slipping or soom to be slipping (worn out ) clutch is:
Results
PaulB
- x 1240
As Anders says, clutch wear may not be apparant until the engine is at maximum torque and full load, at around 2,000 rpm, but a clutch that slips under those conditions can last many more miles if not allowed to slip. My last XM went on for a year or more (15-20K) and was still driving OK when I sold it. And yes, I did tell them it was slipping!
Monkeyfeet
Re the TD estate, ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
new clutch+cambelt 30k ago.
(yes it's mine, but there's no harm trying, is there?)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
paulbx
Clutch test addenum
Kowalski is correct - only use normal accelerationas if you were taking off under normal conditions in 1st
