Lucas EPIC Diagnostic Tool
BonceChops
Unread post by BonceChops »
Does anyone know of a diagnostic interface to laptop tool that will work on my Xantia 2.1TD with the Lucas EPIC system? I have a problem that I think is mainly due to air in the fuel but I would like to read any fault codes that might be present. I spoke to a supplier today and he could not say that it would definately work as they had not tested it on one.
Now Citrtoenless
deian
Unread post by deian »
good question, i'll be keeping an eye on this thread, i've got same engine as you, good luck.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
AFAIK, OB diagnostics didn't become available on diesels until 2004.
BonceChops
It has the OBD connector and the Lucas EPIC saves fault codes that Citroen can read. Also you need to connect to the OBD connector to program the immobiliser to accept new keys.
Now Citrtoenless
Rostami
Unread post by Rostami »
JohnD:
My car is from 1999, is a diesel, uses EDC15C2 from Bosch and has on board diagnosis!!!
Xantia Activa 2.0 HDi (1999)
Renault Clio 1.9D (1994)
BX 16TRS (1984) - RIP
Fiat Uno 45s (1987) - RIP
JohnD
(Donor 2022)
x 72
JohnD wrote:AFAIK, OB diagnostics didn't become available on diesels until 2004.
What I had in mind when I wrote this was OBD that could be read with a DIY code reader.
