HDI back from the dead!
XantiaJon
Unread post by XantiaJon »
Follow up to my previousPost subject: XANTIA HDI DEAD!
New rocker arms fitted, new Cam Belt & Tensioner fitted! All done without removing the head! Running a treat sounds great! Just waiting for the bill! I really thought the car would be uneconomical to repair.
Now I just need the cover from the Cam Belt as my ones got a big hole in it where the tensioner came out! Anybody got one for sale?
Thanks to everybody who posted, especially Kowalski.
Posted: Thu Mar 16, 2006 5:32 pm Post subject: XANTIA HDI DEAD!
My 90 BHP, HDI cam belt tensioner, disintegrated! I was driving at high speed (100 mph +) at the time! Now my engine is shot! Anybody know how much damage is likely to have occurred? The cam shaft pulley rotates with virtually no resistance! I've got 3 options, Scrap it, have the head taken off & hopefully have the damage fixed, or have a 2nd hand
engine fitted. Anybody used Tower engines in London?
My Xantia is W APRIL 2000, is it worth fixing!
Anybody want to buy it for parts LOL? It's just clocked over 71K, New spheres fitted a month ago
Xantia HDI 90, W reg. 80000 Miles.
Peugeot 205 GRD, E reg! Speedo stuck at 411000 miles! Still going strong
Honda
Unread post by Honda »
Congratulations!
What differences should one expect between (1) petrol, (2) old diesel, and (3) common rail engines if the cambelt is blown while driving?
ACTIVE8
x 6
Unread post by ACTIVE8 »
Great news ! :) Well done. :wink:
Pleased to hear that you got your car going again.
x 1240
Unread post by Peter.N. »
Well done! Thats got to be an improvement on the XUD!
James.UK
Unread post by James.UK »
Nice one Jon and Kowalski :D .. Once more the forum members save a Citroen from being scrapped. :D
Is it possible to swop the HDI type rocker arms with those fitted to the XUD engine? If it can be done, then I think it would be a good idea for ZX-XUD owners to do the swop! :D :?: :?
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
reblack68
Unread post by reblack68 »
Honda wrote:Congratulations!
Some petrol engines are designed to be "non interference" and can break a cambelt with impunity. Diesel engines cannot be designed this way because of the higher compression ratio, the piston has to come too far up. Traditionally a broken belt on a diesel has been a disaster. It seems that the Hdi engine has been designed to limit the damage- this was news to me. I've heard of other diesels, the old Transit engine being one, that also bend stuff you can fix easily.
Sadly the XUD cam acts directly on the valve (via a shim and bucket) so it can't easily be modified in this way.
Richard
No French cars of my own at present.
Care of a 1994 205 D.
Kowalski
Unread post by Kowalski »
James.UK wrote:Is it possible to swop the HDI type rocker arms with those fitted to the XUD engine? If it can be done, then I think it would be a good idea for ZX-XUD owners to do the swop! :D :?: :?
Not possible I'm afraid. :( The heads are rather different between the HDI and the XUD and the parts are just not interchangable.
My understanding is that the HDI engine operates its valves via hydraulic tappets and rocker arms where as the XUD operates its valves more directly with the cam above the valves.
When the valve gets forced upwards on an XUD its the cam it is being forced against, the cam is fairly strong but the crank is a lot stronger so the cam and its bearing caps get broken, the valves bent and possibly the head gets damaged too. With the HDI the valve is pushing against a relatively weak lever so that breaks easilly and the valves + cam can escape relatively undamaged.
These two pictures are of XUD heads.
http://www.kouvolanmoottorikoneistamo.fi/images/200.jpg
http://www.kouvolanmoottorikoneistamo.fi/images/256.jpg
And this is an HDI rocker arm.
http://groups.msn.com/honestjohn/proble ... hotoID=156
Differences between petrol and diesel? Diesel engines have higher compression so there is no (or very little) clearance between piston and head when the piston is at TDC. Petrol engines are mostly multi-valve now (more than 2 valves / cylinder) and very few are non-interference designs, there is more clearance than on a diesel but because of the way multi valve engines have the valves at an angle rather than being vertical you tend to get bent valves (and broken valve guides) rather than the catestrophic damage that and XUD will do to itself.
There is no difference between common rail and mechanical injection diesels in terms of breaking themselves when the timing goes. There is a difference between direct injection and indirect injection (common rail engines tend to me indirect injection) in that direct injection engines have lower compression and thus more clearance but these engines are by no means not interference. The trend is for diesels to go multi-valve the way petrol engines did, this is going to mean bent valves on the 16 valve HDIs I would expect, rather than broken rockers that you get on the 8 valve HDIs.
Honda
The XUD may have its limitations but it's indeed a tough engine if well taken care. I have been in a XUD 1.9 with 700.000kms that was still working as a precision clock and, according to owner, almost so economical as first day.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Great news :) have to keep a lookout for cheap HDIs now.
Stewart
x 1240
The 2.1 td XUD has hydraulic tappets and rockers, I've never heard of a cam belt breaking on one of these, has anyone had experience of that happening, what was the result?
f00lzz
Unread post by f00lzz »
Xantia 1.9TD after auxillery belt entered cambelt cover and snapped the cambelt... I have more pic's if this one isn't upsetting enough :-({|=
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Bigjoe
Unread post by Bigjoe »
Before it died at the hands of dozy woman in a golf,i had a Peugeot 406 1.9td 1997 that had done 278k miles,on one of the rare occasions that my dad drove it,it snapped the camshaft into 3 pieces,but the timing belt etc was still intact!? so i rebuilt the top end and checked the block and the block was in beautiful condition,thats why i want a 1.9td xantia estate,as i know the citroen/peugeot diesel engines are bulletproof :D .
Im out there somewhere!
Xantia 1.6i LX (i know but i had to start somewhere!)
