406 Outseide Temp Sensor
rayc
Unread post by rayc »
Can someone please enlighten me as to the location of the outside temp sensor on a 406.
My one is reading a constant 17 degree's whatever the outside temp is.
I would like to see if it has moved from it's correct location (If I can find it!) :roll:
Many thanks in advance
Ray :wink:
pugxpert
Unread post by pugxpert »
located in left hand door mirror ,looks like a little tit on the underside of mirror,new sensor avalible seperate jusy cut and solder in new one
EP6T petrol turbo nice engine in the 207 GT and the new mini....
rayc
Thanks for that info. Will have a look tomorrow morning
Cheers
Ray
fastandfurryous
x 4
Unread post by fastandfurryous »
Replacement sensor is £18 from Peugeot. It would be worth removing the sensor and measuring it's resistance at different temperatures before condemning it.
This is not a signature.
rayc
Ok will give it a go.
It reads a constant 17 degree's whatever. I'll check it out first before buying one
Thanks for that
