has anybody fitted refurbished injectors to there turbo d??
i dont think there is anything wrong with my current ones but do new cause any diffeences like quieter running, more power or better fuel consumption????
refurb. injectors
8304
refurb. injectors
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
- x 1240
AndersDK
bxbodger
I did the ones on my (non turbo) BX at around 200000 miles, as it was getting a bit marginal on the smoke test and the usual cures didn't work- the old injectors were recessed round the tips with the needles protruding slightly, upsetting the spray pattern.
It made no difference to performance or consumption, but dramatically improved results on the smoke test, and it sounded a bit more knocky.
the only other difference was that it had always been a tiny bit jerky to drive at slow speed/low revs- that disappeared.
I'd leave well alone until the smoke tester tells you otherwise, and don't bother shelling out for injector cleaner- its repackaged paraffin....!!!
