Hi All
Purchased an Xantia 1998, with RF locking, but the original RF key was missing.
Purchased a replacement RF key, but stuck with getting it to talk to the car.
I have AUTODATA CD but its a bit vuage,as it says "Wait for system LED to extinguish - if fitted".. Whats that refering too??
It then needs the system LED to light for 0.5 of a sec..
How do I know the Key is working at all?? I've checked the battery, it has 2.89 volts, and the key switches do work, I've checked these with a meter..
anyone help please?? Many thanks
citroenxm
1999 Xantia Remote programming
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1056
- x 1056
Re: 1999 Xantia Remote programming
that sounds as if its referring to the transponder imobiliser system.citroenxm wrote: it says "Wait for system LED to extinguish - if fitted".. Whats that refering too??
BonceChops
Is it a new key? Does the key start the engine? You need the diagnostic computer to program the key to start the ignition but I am not sure about making the RF plip open the doors. I have read that you don't need it for that.
I found this info somewhere on the net that you could try
Please let me know if it works as I have a plip from another car I need to program to my car. I can get the transponder reprogrammed to work the ignition as I know someone with the diagnostic computer.(2 BUTTON PLIP KEY) Procedure 1.Ensure all doors are unlocked using the key. 2.Press and HOLD the large plip key button while the LED flashes con-tinuously for 20 seconds. After 20 seconds press the small deadlock but-ton once while still holding the large button. 3.The LED will stop flashing.
4.Release the large button and the LED will light constantly. 5.Press the large button one time, and the LED will go out. 6.Open the door and hold the Plip key near the Ignition switch, and press the large plip button one time. 7.Now turn the ignition ON, and wait 10 seconds then turn ignition OFF. 8.After 5 seconds, Plip should now operate.
Now Citrtoenless
Now Citrtoenless
