hi everybody...
just been thinking, i know that mechanical injection diesels dont have fuel pump as such but what lifts the fuel from the tank, am i correct in assuming thereis a lift pump in the diesel pump?? mine has the bosch type pump...
also, i have ordered a new supply fuel line for my zx to see if that cures the suspected air leak which is making the car run poorly on start up. ill keep you posted.......
cheers
alastair
zx td 94
sooty
The fuel lift pump is built into the Injector Pump.
I have read somewhere, that someone with Bosch Fuel/Starting problems, fitted an additional cartridge/cannister type filter above the highest part of the fuel system ie:- injectors. This giving a head of fuel and any air would collect in the fiter not the pipes and keep the injector pump full of fuel. I think it was on the Old Forum with an Xantia, worth a search ??
Before any further suggestions are made, you did not reply to what Anders or myself suggest you try, to see if any effects where made when running from start-up "rough running and white smoke etc."
Ex 307 2.0Hdi 90 bhp 2003
Ex Grand C4 Picasso VTR+ 2008
Ex Vauxhall Insignia SRI 2.0 CDTi 2010
C4 Picasso 1.6 HDi VTR+ 2014
8304
sooty wrote:
"Before any further suggestions are made, you did not reply to what Anders or myself suggest you try, to see if any effects where made when running from start-up "rough running and white smoke etc."
are you asking if the car runs roughly and produces white smoke? if so yes it does....(when cold)
the car generaly starts on the button like really quikly probably the second spin of the engine, it will then run fine for about 5 seconds and then go lumpy - i think that it the five seconds of smooth running the engine is suking air in from the fuel line - i think the engine is starting on the fuel left in the fuel pump as it did when i did the engine change on the car and started it without the fuel lines connected just to see if it would.
anyway ill let you know if changing the pipe changes anything....
alastair
alastair
Zxtd Aura converted from 1.8i Petrol - Lowered, 20psi boost extra fuel - weeeeeee!
MK2 Cortina 1600e
Honda Acty Romahome - 545cc!! - (the "beast")
MK2 Cortina 1600e
- x 1240
jeremy
- x 3
sooty
jeremy
- x 3
