Xantia Diesel Lost Power and Smoking like hell
jeremy
If the exhaust is blocked you will get a build up of of air and exhaust. This will impede flow round the turbo and stop it working properly. It will also mean that the cylinders won't empty properly meaning that there will be a shortage of oxygen available for combustion - so unburnt fuel will be present in the exhaust.
jeremy
bman
- x 1240
bman
just a thought it was getting slow then towed an unladen car trailer about that was when i realised it was strugggling then when i picked up a megane on it it really struglled but got there just but now its like i've got a sherman tank in the boot, will get mi welder out and make up a de cat pipe i guess
zzf00l
jeremy
Just a couple of things - the rear silencer and other bits of the exhaust may be clogged as well - but probably the catalyst is the first to do.
The second point is that there is a risk that the greasy dirt in the silencer may burn off - resulting in smoke and the posibility that it will continue to do this when its stopped. this had happened to me and I thought at the time the best thing was to keep driving gently - to keep air moving over the exhaust to cool it and prevent excessive heat transfer to the car.
jeremy
- x 1240
Allanxantia
- x 1240
Kowalski
bman
Problem solved!
cat was buggered but that might have something to do with the embedded exhaust turbine and bush..... although the current turbo is fine, thinking it must of gone bang in a big way on the previous owner and the remains never recovered anyway goes like stink with the straight pipe. magic
thanks to everyone for the suggestions
- x 1240
