'Pinking' BX 19GTi
PJ
'Pinking' BX 19GTi
Unread post by PJ »
I have a 1991 (H reg) BX 19GTi. It uses the Motronic MP3.1 ignition system, - no CAT.
The Problem I have is that on 'mild' acceleration, it 'pinks' (pre-ignition) - On 'harsh' acceleration 'pinking' is not present.
Is there anything a DIY person with a multimeter and a few tools can do here? - or do I have to entrust it to a Citroen dealer? I would normaly want to adjust the timing a bit, but I understand this is not an option due to the ECU controling it all.
Regards, Paul.
jeremy
x 3
Unread post by jeremy »
Have you checked basics like plug type? - might be wrongg heat range.
Otherwise make sure all your breather hoses are good and tightly fitted - possibly an air leak could weaken the mixture on one or more cylinders.
While the 8 valve GTi is relatively low compression have you tried a different fuel in it? I remeber in the days of leaded petrol I had a Scirrocco GTi and ran it exclusively on one of the major brands of fuel. Over a couple of weeks it went from beautiful to horrible and I was thinking a tuen up was necessary. I got 'caught short' one night and had to put another brand in - wow - just ran perfectly. The same brand would make my XJ6 pink as well - their diesel seems ok!
Shell sell a newish higher octane fuel which may help (Optimax?)
Jeremy
alan s
RIP 2010
x 6
Unread post by alan s »
Paul,
I am not 100% sure that you are correct in saying you can't adjust the timing.\The reason I say this is that one of my sons bought an absolute doll of a TZi BX a year or so ago with only 90,000 klms on the clock. When I drove it, the damn thing was bucking & pinging and felt generally terrible to drive & the car had service records that said it had been serviced by a specialist with a good reputation. I spotted that the distributor had two bolts on it with slots in the base of the distributor, so I grabbed my strobe timing light, scratched my way through the myriad of pipes & wires at the front of the motor until I accessed the hole in the bell housing where I could see the flywheel & found the timing was waaaaay out. Readjusted it to where I reckoned it should be & it's never pinged or missed a beat since.
I don't know the type of system you have, but if the distributor has slots in its base, it's possible to adjust your timing.
I have been running on the highest octane available (98 octane) ever since & get terrific fuel consumption & performance almost up to the standard of my 16V
Worth a look in case yours is the same. Incidentally, the previous owners of my sons car were also told the timing was non adjustable.
Alan S
PJ
Unread post by PJ »
Alan,
Thanks for your reply - my earlier 19GTi had the type of distributor that you mention here - however, my current one has not got a distributor and rotor arm - it uses the 'twin coil and wasted spark' method (i think that's what it's called [:I]) Hence the distributor is just 'bolted' on in the traditional position as somwhere to put it! Moving it will have no affect on ignition timing!
Jeremy - you mention this 'Optimax' from Shell - a few other people rate this fuel as well - so may be I should find some and try it!
The Plugs by the way are the correct spec' - but they could probably do with a change. A few things to try.
Thanks.
Paul[:)]
jeremy
x 3
New plugs may help - a build up of deposit can glow and cause pre-ignition. The heavy deposit on the side electrode could also cause problems.
jeremy
Homer
x 16
Unread post by Homer »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PJ</i>
I had 4 BXs (3 1.6 petrol and a 1.9 petrol with a cat) <b>none</b> of them ran very well on Shell. Optimax wasn't around at the time though.
jeremy
x 3
I haven't tried 'Optimax' myself as I'm currently running a couple of diesels but I think its rated at 98 octane. Ordinary (UK) unleaded is 96 and the GTi would have been designed for 98 - hence my suggestion that this fuel is worth a try.
To be fair to ordinary unleaded it sems to run well in many vehicles and isn't as prone to pinking as old leaded was.
While the 8 valve GTi isn't exceptionally high in its compression at 9.3 its in a range where ordinary unleaded may cause trouble.
My XJ6 at 8.75 :1 used to run better on the then available super + unleaded than it did on leaded. My Renault 21 (10 : 1) ran just as well on ordinary unleaded as it did on leaded (much to my surprise!)
Jeremy
alan s
RIP 2010
x 6
I'm a bit of a high octane "junky" I suppose.
Where I am, I can get "Premium" unleaded" which all of our cars seem to run fairly well on.
I have used Optimax (98) in my sons TZi manual & it runs slightly better and I have also used BP Ultimate (98 also) in it & it is on par if not slightly better.
In contrast, my BX 16 Valve runs well on "Premium" (96 octane) yet the 98 stuff doesn't seem to make a scrap of difference to its performance.
Strangely enough, the greatest amount of improvement in any of our cars is in our series one CX 2400 Pallas c-matic...don't ask me why, but this car feels like it grows two extra cylinders when filled up with the 98 brew.
It's not imagination either; everyone notices the difference within about 5 miles.
Alan S
Jon
Unread post by Jon »
Um, well an 8v BX GTi should run perfectly well on normal 95ron unleaded, and indeed the 2 I once owned many years ago ran just fine on this.
Lets go back to the original post from which we note that the car "pinks" on mild acceleration. Surely pinking/pinging will occur when the engine is under load, accelerating up hill, or using full throttle. You would not expect a car to pink on a light throttle would you?
To my mind this sounds more like some kind of fuel or ignition induced hesitancy. I would start by cleaning up the airflow meter flaps and body with suitable spray, then run some injector cleaner through the fuel system. Also check/change plugs and leads. If no better we could be looking at something like a duff water temp sensor which is giving the ECU false signals and making it run too rich???
PJ
Unread post by PJ »
Thanks Jon,
I have replaced Air-filter - no change! but have not looked at plugs yet!
Can a DIYer check the water temp sensor function? or is that something that the computers at a Citroen garage has to find out?
Paul.
