I've noticed recently since I cleaned out my LHM reservoir (the car's now back together and being driven)that there is a slight leakage of LHM fluid on top of the reservoir.Its not obvious where the leak has sprung from.
Can someone tell me,do "all" the hoses/pipes have to be secured where they terminate at the reservoir head pipe connections?
I ask this because before removing the said pipes/hoses all but 3 of them were secured by original citroen type hose clamps(which have been replaced).I know that most of the hoses are return hoses and may not warrant securing with hose clamps,but I'm just wondering if someone prior to my ownership of the vehicle has tampered/ill-maintained the car.Before anyone ask's ..'no',there was no leakage prior to my cleaning of the reservoir.
Also I have filled the reservoir to the correct level using the proceedure of having the car on its highest suspension setting etc etc.
I know I could try and put hose clamps on all the said pipes,but is that really necessary,plus it'll be a fiddly job because of all the connections being so close(Thanks Citroen !!)
Can any one put this mind of mine at rest...please...Thanks
Steve
