I kept getting the warning "Unblock Diesel Filter" showing on screen.
I changed the filter, but, the warning still comes up but not as often.
Any ideas
Thanks in advance
C5 Diesel Filter
wigelywoo
C5 Diesel Filter
There are two secrets to success
1. never reveal all you know
Horse
- x 1044
pugxpert
you will need to check your additive tank is not empty first if that is ok and you have already changed fap filter you will need to get your counters reset in additive ecu this tells engine ecu how much additive is loaded in fap filter,also driving the car for 20 mins at a constant speed say 100 kmh this should trigger the engine ecu to start regenerating filter to unblock it.(if your additive tank is empty this will not work).one other fault you may have is with your pressure differential sensor for the particle filter,if this is faulty you will get filter blocked warning as this is where it gets its information from for the state of the filter,some 307 sensors were prone to getting water inside them,hope of some use
EP6T petrol turbo nice engine in the 207 GT and the new mini....
