Exhaust on 406
Gotta New Pug
Exhaust on 406
Unread post by Gotta New Pug »
As im on here, I thought i'd as a simple question, if my exhaust is making a metallic rattling noise around the centre box - does this mean a baffle has broken off? And if so would it fail an MOT for it?
Cheers
bad driver
Unread post by bad driver »
Have you got underneath and checked it not rattling against the heatshield? If its not then might be an idea to remove the centre section and give it a shake, see if anything comes out. Yes it can fail MOT.
Gotta New Pug
Hmmmm, thats an idea..... will get under it later when ground has dried up a little! Damn car is nothing but trouble.
Cheers for the reply mate.
tonespeed1999
Unread post by tonespeed1999 »
the exhaust will not fail its mot test if it rattles.
it can only fail the mot if its leaking/blowing or if the cat,s not working,and if its insecure.
jonasy
Unread post by jonasy »
not so serious like you think, remove and change a new last section of exhaust.
PowerLee
Unread post by PowerLee »
What normally happens on a 406 is the centre pipe rots through where it joins the back box & because of the rubbish design & where the hangers are located the hot tailpipe then tilts up & melts the bumper.
