Jumped in the car the other evening (yes it was dark) and switched on..... headlamps illuminated by themselves!! Oh, I thought, must be a sensor I did not know about and started the car up OK. This morning, turned the ignition on, all came on as usual but when turning the key to START position, all I got was a click from the starter and then all hell broke loose!! Could hear umpteen clicks, relays chattering, flashers going, beeps from the dash area etc. No Go !! Tried again this evening and the electrics seem to have gone ballistic - headlights come on by themselves, relays go berserk, flashers on, CD changer clicking etc etc etc. Anyone else had this most interesting experience? Could it perhaps be a loose/bad battery connection? Lights are fine when switched on so I do not anticipate battery at fault... stuck motor? Solenoid defect? Relay defect? Bad earth somewhere? Brain gone mental? Any advice most welcome!!
Regards,
John.
P.S. Just sold the AX - maybe I unloaded the wrong car from my Citroen fleet !!
C5 Gone Haywire !!
johnway
C5 Gone Haywire !!
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
jeremy
pugxpert
NiSk
Check the voltage of the battery - should be about 13.5V for a fully charged battery at rest. Anything less than 12.5V and you need to charge it first.
Perform a power reset.
1) Make sure you have the code to any radio etc!
2) disconnect the negative terminal from the battery for 10 mins.
3) reconnect.
If this doesn't help I'm afraid your'e in for a battle with the electro-gremlins!
//NiSk
3) reconnect.
//NiSk
AndersDK
Sir Clive
Sounds like a flat battery. or at least one thats well on the way to being flat. When I carelessly left the sidelights on, I had exactly the same thing on my C5. It went absolutely bananas when I turned on the ignition. 15 minutes on the nice AA mans jumpleads soon had everything back to normal though!
johnway
C5 Gone Haywire!!
Thanks to all who offered advice - was especially pleased that another C5 owner had experienced the same problem. I shall take all advice on Saturday - remove battery, recharge and install after a suitable period of time has elapsed before "rebooting"......fingers crossed!!
Regards,
John.
Regards,
John.
Sir Clive
johnway
C5 Gone Haywire - not!!
Hello everyone,
Delighted to report that my 2002 C5 is now working great!! Charged battery (after checking levels), cleaned and greased terminal posts/clamps et voila! Toute est bonne!!
Thanks for all suggestions. Merry Xmas to all,
Best Regards,
John.
Best Regards,
John.
