Kowalski wrote:Mig is pretty easy to learn. If you start off with a selection of offcuts of steel, varying thicknesses etc, and weld them together, after half a day of that you'll have it worked out.
I agree MIG welding is relatively easy to learn, and it's all about practice, lots of practice.
As Kowalski said use some offcuts, and carry out work on some test pieces, so you can learn the technique. It should also be noted that if you are inside in a well ventilated garage/workspace a better weld can be achieved.
Why ?
Well when you are inside you don't get the weather affecting your work so easily, I.E. a sudden gush of wind blowing away the gas shield from the work area.
Also, being inside also helps the safety of others who could accidently look the wrong way, and get "Arc Eye."
