Hi all,
New member here. Problem is this..
My remote died and a year and a half later i have bought one from ebay.
Can any one tell me how to program it? I hope that it does not need the car door locking or unlocking using the key as the door lock has seized. Simple? I think not.
Car is a ZX 94 td Aura.
I hope someone can help.
Mark
94 ZX Fob Programming
rossnunn
nuts250
ZX Fob Programming
Thanks Rossnum.
I heard that an IR fob can be, without changing the receiver. Any body else got some ideas?
rossnunn
- x 1432
I think the ZX ones are the same as the BX ones, and they can be re-programmed to suit different receivers. However, you need a soldering iron, and need to be handy with it! I think the code is decided by which of the pins on the IC are grounded, and the recevier and plip need to match. There was a set of instructions floating around on the web a while back, but I can't remember where.
Edit: Found it! BX Remote Coding
