C5 pollen filter
brian.r.uk
C5 pollen filter
Unread post by brian.r.uk »
can anyone out there tell me where i can find the pollen filter in a 2002 C5 2.0 hdi sx.
thanks Brian :?
406 V6
Unread post by 406 V6 »
It's accessible from the front passenger's side.
From memory, it sits right above the tranny tunnel, in the direction of the gear lever. ;)
Francisco
C5 2.0HDI smoothly riding on 1.8l version spheres :D
When the hearts beats like a pressure regulator you know it means one thing: Love
Citroën - pacemaking since 1955
brian.r.uk
thanks i found it today. you have to remove a small plastic panel to the right rear of the passenger footwell (right hand drive) on the side of the transmision tunnel.also remove the carpet trim under the glovebox.filter is secured by two 8mm headed srews then slide out.thanks for the reply
brian
mezuk04
Unread post by mezuk04 »
Can pollen filters be reused??? (referring to the Xantia)
Volkswagen Golf 59' 1.6TD S :(
brian.r.uk
the filter in the C5 is about the size and shape of an oblong air filter but the element is made of a fluffy fibre material so could not be cleaned should think the xantia was the same.the fibre material is light grey,mine was black certainly needed changing.
London luke
Unread post by London luke »
Ive washed mine this morning (Xantia) looks much better and no damage. Smell nice too !
