Hi Guys,My Xantia TD is running okay, except that the water temperature isn't getting too hot, therefore I only get luke warm air when I turn the heater on.
Now my guess is that the thermostat is knackered, am I right?
The needle on the gauge used to get to the middle line and stay there, now it doesn't reach so high!
I have flushed the system when I put new anti freeze in and have bled it of air too. It's had a new heater matrix so thats not the problem either. The fan works ok and the heater controls are ok too.
Paul
Xantia Coolant not getting hot
wrinklet1
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
Clogzz
- x 40
Re: Xantia Coolant not getting hot
I'd say so, the thermostat must be stuck open, not a good idea for winter.wrinklet1 wrote:my guess is that the thermostat is knackered, am I right?
Also check that the cooling fans are not spinning for no reason, because that's the Xantia's favourite fault.
The fans shouldn't spin until the temperature reaches about 90ºC, or when the air conditioning is on.
2002 C5 2.0i AL4 239,000 km 76372389
wrinklet1
JohnT
- x 1238
London luke
James.UK
It may help to use the old trick of putting some cardboard in front of half the radiator, you just take it out when the weather warms up a bit..
My old Jag had most of its radiator blocked up that way every year because it ran too cold otherwise..
edit.. Thermostat.. Follow the big pipe top right from your radiator to the engine block, undo the bolts that hold it on, and the thermostat is normaly in there... You need to clean both surfaces and fit a new gasket when you put your new themostat in, then. bolt it down again, add more coolant and bleed the system... It is normaly a very easy job..
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
Clogzz
- x 40
fastandfurryous
- x 4
I think 70 is a tad low. My 1.9TD runs at a shade under 80 no matter what the weather.
It could also be that in actual fact, your engine is at the correct temperature, but the gauge is innaccurate. I would be surprised if any temperature gauge on a car is accurate to closer than +/- 5 degrees. I know for instance that mine has a shift of about 3 degrees on it (temp gauge actually reads 81, engine runs at 78.)
This is not a signature.
mezuk04
dnsey
- x 19
Clogzz
- x 40
Looks like all that's got to do with gauging is inaccurate on the Xantia.fastandfurryous wrote:I think 70 is a tad low. My 1.9TD runs at a shade under 80 no matter what the weather.
Most of the time, my temperature gauge is also just under 80ºC.
When it's relatively cold, say less than 13ºC, it shows 70ºC.
The fuel gauge is also strange, once I ran out of petrol with the gauge still showing a quarter, and the low fuel light hadn't come on.
I'm under the impression that the gauges are very sensitive to voltage.
Same inaccuracy for the oil dipstick.
4 litres shows full on the stick, but the oil level warning light sometimes flickers.
5 litres shows too full, but the oil level light stays out.
adzbaby
Thermostats
(Am chuffed I have found the old forum)
I have changed a few thermostats and found that there a least two stats that are compatible with the Xants. I have found two types of valeo which did give different temp readings, one gave a temp of 80°C all the time and the other would result in 90°C. There is always a bit of variation with cars and their guages.
jeremy
