HDI hesitant on small thottle opening
tony1
I took a 2002 HDI 90 Berlingo for a test ride today, it is the first diesel I have driven. I noticed it was a little hesitant on small throttle opening i.e. as you pulled away. Is this usual, or should I look else where?
02 - Berlingo HDI Forte
drpau
Sounds normal - at the front of the engine (on my xsara anyway) the end of the accel cable connects to a hmmm eletronic actuator type thing (its name escapes me right now), if you tighten up the cable a bit it really makes a difference to the throttle response. I tightned this on mine and it made it feel much livelier. I assume it will be the same for the berlingo....
Cheers
Paul
Cheers
Paul
99 Xsara SX HDi 105k with PSi power box- smokier but well worth the wonga!
- x 1240
fastandfurryous
- x 4
Implying that you now aren't alive?Peter.N. wrote:......used in to vary the volume in radios when I was alive.
Que?
As for the hesitant HDI engine.... it could also be crud from the EGR valve choking the engine at very light loads. Seen this in a 1.9TD engine, and there's no reason why an HDI wouldn't suffer this way too.
This is not a signature.
- x 1240
