Fuse didn`t blow !!!
Post Reply
gaz238
My Cars:
Post by gaz238 »
Please could somebody throw some light on the following problem - first of all the car is a citroen c5 2002 model. today whilst trying to get a dvd car adapter out of the front 12v socket, the socket sparked and I presumed it had just blown the fuse. However, the fuse was ok but both 12v sockets (front and boot) and also the switch in the boot to lower/higher the rear suspension now doesn`t work. I can`t believe the fuse didn`t go. Has anyone any idea what might have happened ??. :shock:
gazza
My Cars:
x 732
Post by wheeler »
have you checked ALL the fuses.
My Cars:
x 92
Post by citronut »
maybe there is a secondry fuse box
regards malcolm
gaz238
My Cars:
Post by gaz238 »
Thanks for your replies. I have only checked the fuse that in the manual refers to the 12v socket and the boot suspension switch. This fuse is under the dashboard. Also, the same fuse according to the manual works the front elec windows which are ok. Is there a secondary fuse for the same circuit ?
gazza
Post Reply
