Hi.
Xantia 1.9TD 1999
Can anyone offer some advise/info. please.
Developed massive hydraulic leak from (i think) the supply pipe where it meets the regulator.... this has happened before and was cured by replacing the pipe and the stud that was missing which supported the pipe to the gearbox. It seems that the slightest movement will crack the pipe/break the seal.
However this time closer inspection reveals that the regulator is loose and one of the studs holding it to the gearbox is missing plus the single stud right on the end of the regulator is also absent. Can anyone assist by telling me which size studs I should be replacing them with and if it is possible even to replace the one at the end of the regulator?
Hydraulic Pressure Regulator
zzf00l
Sutton Coldfield, West Mids
Xantia V6 Exclusive (2000
Xantia 1.9TD SX (2000)
Previously owned
Xantia V6 Exclusive (97)
XM V6 Exclusive (95)
AX 1.4
Previously owned
AX 1.4
Stewart(oily)
- x 35
I believe the missing studs/bolts are M7 thread with an 11mm head, they are often omitted/broken when blunt fingered oaves do the clutch
they mistake Xants for 405s and find out about the PR too late to avoid breaking things.
Stewart
Stewart
- x 94
mpr1956
I'm glad I read your post... My PR is loose, -I assumed it was to help absorb the vibration ! On a positive note, at least it is likely that the clutch was recently changed before I bought the car as claimed by the seller. Righto, I'll be off to get some bolts and secure my PR !
I won't do that again
- x 94
zzf00l
Thanks for that....a trip to the local scrappy i think as M7 are fairly rare! the bolt theough the body of the regulator looks like it might be approx 75mm any idea about the one on the end of the regulator?
Ian
Ian
Previously owned
AX 1.4
Previously owned
AX 1.4
zzf00l
Exactly ny thoughts,,,about 12 months ago I had bearings replaced in the gearbox (Citroen 'Specialist' in Oxford) and since then have been replacing/tightening.re-locating bolts. these are two I obviously missed.Stewart(oily) wrote:I believe the missing studs/bolts are M7 thread with an 11mm head, they are often omitted/broken when blunt fingered oaves do the clutchthey mistake Xants for 405s and find out about the PR too late to avoid breaking things.
Stewart
Previously owned
AX 1.4
Previously owned
AX 1.4
zzf00l
Managed to get the bolt holding the regulator to the gearbox from a local scrappy in Brum.... a mint VSX 2.0i with oatmeal leather interior, how could someone do that ????
Previously owned
AX 1.4
Previously owned
AX 1.4
- x 94
zzf00l
zzf00l
Just thought I would give an update on the 'missing bolt' syndrome. For some time I have had a slight clutch judder which recently got worse accompanied by an 'exhaust rattle'.... To cut a long story short I cannot find ANY gearbox to engine bolts and the engine and gearbox have seperated by approx 12mm!!!!! If I could get my hands on the 'mechanic' at CITROEN CENTRE in Oxford I would gladly throttle him.
Previously owned
AX 1.4
Previously owned
AX 1.4
zzf00l
FrenchLeave
- x 1240
zzf00l
To be fair, I have purchased both my current Xantia's from him and the 3.0 never misses a beat...... but surely this is down to poor workmanship and very annoying, not to say costly. With regard to contacting him, whats the point! It will only wind me up even furtherFrenchLeave wrote:Have you 'phoned Paul whatsisname and told him? It'd be interesting to hear his comments.
Derek
Previously owned
AX 1.4
Previously owned
AX 1.4
