Xantia TD Rev Counter
johnway
Unread post by johnway »
Hello,
This is a good'un - when I lift off the go-go pedal the rev counter drops to zero, only to spring back into life the instant I touch the pedal again. Not a big problem but a little irritating - any ideas?
Thanks,
John. :( :( :( :(
My chariots : 2002 Pug 406 110 HDI Executive Estate 138K
1995 Citroen AX 1.0 Debut 26K
I Blame it all on my Dad!! (Sadly had to give up driving & his 2nd BX) but Mum still has a C1.
j_roc
Unread post by j_roc »
Could be the pickup sensor is playing up. You may be able to take it off and give it a clean with some carb cleaner/switch contact cleaner. Or if you are a fussy (like my dad :roll: ) buy a new one. Hope this helps - Alex.
x 94
Unread post by citronut »
sounds like a bad conection,every time you give it some gas the engine twitches and moves some wires,check the plug conector on the pick up wire
regards malcolm
x 94
[quote="j_roc"]Could be the pickup sensor is playing up. You may be able to take it off and give it a clean with some carb cleaner/switch contact cleaner. Or if you are a fussy (like my dad :roll: ) buy a new one. Hope this helps - Alex.
it only a pole sensor incased in plastic so there is not much to clean,apart from the pins in the plug conector
regards malcolm
johnway
Pole sensor
citronut wrote:
j_roc wrote:Could be the pickup sensor is playing up. You may be able to take it off and give it a clean with some carb cleaner/switch contact cleaner. Or if you are a fussy (like my dad :roll: ) buy a new one. Hope this helps - Alex.
regards malcolm
Hello,
Thanks for the info - now where is this sensor located please?
Regards,
John.
