<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RoadkillUK</i>
I know suspension has been covered before (a little) but I can't seem to find a message that covers ALL my problems
R reg, 1998, new shape.
1.9 TD Saloon.
I've owned this car now for over a year, shortly after I bought it, the plastic connector for the rear height corrector broke and I got it replaced, it's still in one piece so I doubt that's the problem.
So you checked its still intact after the problem you described later in the message ?
Firstly, when I park up my car it sometimes drops down but not fully, now as far as I know it's not meant to. When I start the car the next morning, as I'm turning the engine over (before it 'catches'), the car then drops to the floor fully. (This has happened since I got the car)
Most likely the anti-sink sphere at the back needs replacing. This sounds like normal behaviour for a flat anti-sink sphere.
Just yesterday, I noticed the height of the back end of the car was very low and that would explain why the ride was so harsh. I took the car up to it's highest level no problem, but then I tried to put it back down to the floor again. The front went down no problem but the back stuck up in the air still and I had to drive it home from work like that.
I parked the car up for the night and the front dropped a little (like I explained earlier) but the back stayed where it was. This morning I get into the car to go to work and as I'm turning the engine the back end sinks to the floor again.
To summerise ... the car sinks when it shouldn't (parked up and starting engine), the back end has 2 positions atm .. in the sky or on the floor.
I have been told (over the phone) that the problem is most likely to be the 'Height Corrector', at £85 I'd like to be reasonably sure that this is the problem.
The actual height corrector unit seldom ever gives problems as it is an extremely simple and self-lubricating device, but the linkages that connect it to the anti-roll bar and the manual height override control are not so reliable and especially at the rear are prone to rusting/seizing up especially if the manual height control is seldom used. (The pivot points of the linkage literally rust together)
If you can back up the car onto some stands which will allow you to look under the car safely while the suspension is right down you should be able to inspect this linkage and give it a good dose of penetrating lubricant (I prefer LPS) then working the manual height control lever back and forth.
Assuming it frees up properly you probably want to grease the joints in the linkage to help prevent it happening again.
Usually the reason for the plastic linkage snapping in the first place is the other linkages seizing up putting too much strain on the plastic.
There are lots of posts on the forum with more details about this common problem.
Regards,
