Xantia-brake pipes my no9 needs replacing
c.morewood
x 55
Re: Xantia-brake pipes my no9 needs replacing
Post by c.morewood »
I've got a couple of threads running this subject.. I've just seen citroenxm' s reply I'll copy it here
"Ok. Im fairly certain theres only 4 front to backs. 3x 3.5mm pipes and 1x 4.5mm and a plastic low pressure return.
a 4.5 pipe goes From the abs block to the rear NEAR SIDE K joint.
a 3.5 mm pipe goes from ONE of the joins on the bulk head for the brake valve to the rear height corrector
A 3.5 mm goes from the height corrector to a push fit return at the front just below the lhm tank
A 3.5mm goes from the safty valve to the OFF SIDE K joint to feed the suspension.
The 6.5 is a plastic low pressure return line"
I hope this helps
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
