ABS module fault
Tomsm
New User
ABS module fault
Post by Tomsm »
Hello
Renault fluence 2.0L petrol (2011) with 165,000km.
A week ago, shows ABS fault, with OBD scanner check indicating on ABS computer - code U0121. Resetting the code didn’t work, it keep requiring with car startup. All fuses are OK. A mechanic changed the ABS module with exact same part number from another vehicle.
Now the car only shows small ABS light on (ABS still does not work) and the Odometer showing 220,000km :shock:
Does anyone knows what is going on??
