Losing the will to live.......intermittent fault!
- Donor 2023
- x 430
Re: Losing the will to live.......intermittent fault!
Roller skate, haven't heard that in a while.
Husky.
- x 3
I forgot how fun little cars are to drive, my dailies are a v70 and a Touareg
- Donor 2023
- x 430
Oh yes , stepping back to them small cars can be fun . Hope you manage to sort the cars issue
Husky.
- x 3
One of my mates has a garage so off to use it (and tools) tomorrow........I'll feed back what I find
- Donor 2023
- x 430
Best of luck hope you find the source of the problem
Husky.
- x 4
If it gave out black smoke its way overfueling, if it hesitates for a second its underfuellng. Both those symptoms
point to fuel delivery. I find it difficult to accept that there are no error codes in the memory.
Have you had them read with a garage which has decent diagnostics?
Black smoke will also be there if the car has been cranked without starting and derv builds up.
If you are getting excessive grey smoke that is also overfueling.
Am not sure I have answers but it may stimulate the grey matter.
If it cuts out on hard acceleration then thats back to underfueling. I had this problem and found a collapsed air filter.
If waste gas is not escaping correctly like a blocked catalyser then all those symptoms may apply.
- x 3
It’s been to a garage that has the Citroen diagnostic gear so seeing it’s French no it’s probably not the best there were no fault codes at all except glow plug relay which has been repaired today! Also the air filter is good!
So changed no.4 glow plug today and that’s cleared the glowplug relay fault, cleaned MAF sensor as it was pretty s**t up, checked all wiring that I could see and that looked ok! Sprayed around air intake and there’s been no searching. Let’s see what happens in the morning, been given to the end of the day tomorrow before it get weighed in for an Urban Cruiser
- x 4
You need to have the car scanned again tomorrow after the changes you have made. Glow plug codes are only an indicator to a variety
of issues. A bit like a pyramid with the real issues drilling down on the scanner codes.
You are in to a spiral of changing parts in hoping you hit the jackpot? Perhaps the original diagnostic technician did not provide you
with a competent read out?
Diagbox can really drill down and find the error with a good operator who understands the process. You have assumed they did.
- x 4
The diagnostic search needs to search specific areas and not accept general codes emitted by the ECU.
- Donor 2023
- x 430
