WindyMiller
Donor 2023
Unread post by WindyMiller »
Hi Marc, perfect, but my mistake, I meant to ask for the steering coloumb universal joints.
Regards
x 6919
If it's item (52) Steering Wheel Shaft, (which I think includes (2), as (2) is not available separately, then it's part: 4103G6, however these are no longer available from Citroen :(
Orbit Motors
x 20
Unread post by Orbit Motors »
GiveMeABreak wrote: 16 Jan 2023, 12:58 Complete Outlet Water Tank Housing, part: 1336L7 (No longer available), however there are some components of the housing available individually. You'll have to provide me with the item numbers for any that you are interested in.
Many thanks for all of this!
If there are some part numbers for the various sensors and any gaskets this would be very helpful as I think I'll probably end up just rebuilding my existing one.
Reason: Removed non-relevant part of quote
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
x 6919
@Orbit:
The only items from the above Outlet water tank that are no longer available from Peugeot are:
(1) Complete Tank, (8) Water Temp Sensor, (10) Water Temp Sensor, (71) Multi-Flanged Bolt.
(2) Engine Water Housing Seal, part: 133962, £2.89
(3) Coolant Drainage End Piece, part: 1336N7, £22.10
(4) Engine Water Housing Seal, part: 134062, £0.54p
(5) Engine Water Housing Cover, part: 1336C9, £26.84
(6) Engine Coolant Thermostat, part: 133823, £58.94
(7) Engine Coolant Thermostat Seal part: 134048, £7.27
(12) Plug, part: 133632, £10.70
(70) Flanged Bolt, part: 6913D1, £2.54
(72) MUL Screw, part: 692254, £2.22
dylan26__
x 22
Unread post by dylan26__ »
Could i have a diagram for the rear tail light assembly on a 2012 DS4.
If the led part of it dies out does the whole assembly need to be replaced? it seems to be a hybrid of led and halogen.
Thank you :)
RuiV
Donor 2023
Unread post by RuiV »
Can you please get me the exhaust system circuit drawing and part numbers (particulary the EGR drawing and part numbers, if the whole system is too mutch)?
Thank you in advance
x 6919
dylan26__ wrote: 18 Jan 2023, 16:55 Could i have a diagram for the rear tail light assembly on a 2012 DS4.
Thank you :)
You must supply your VIN in all requests (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
x 6919
RuiV wrote: 18 Jan 2023, 17:18 Hi,
Let me know which Items you require part numbers for from Diagram A, B or C you require:
Diag A EGR
Diag B Emissions Sensors
Diag C Front Catalytic / DPF Exhaust System
RuiV
Donor 2023
Thank you. ;)
Please send me partnumbers list of Diagram A
x 6919
(1) Gas Recycling Tube, part: 98 130 548 80
(5) EGR Valve, OEM part: 9829870080 or Exchange EGR, part: 1679828480
(8) Seal, part: 9813068180
(10) EG Water Exchanger, OEM part: 9813050280, Exchange part: 1679828380
(11) Seal, part: 9813055180
(13) Cyl Head Cover Stud, part: 025093
(15) Bypass Actuator, part: 9813054180
(18) Stud, part: 0341H9
(70) Flanged Bold, part: 692545
(71 (Flanged Bolt, part: 1611567380
(73) Flanged Bolt, part: 692569
RuiV
Donor 2023
again, thank you :)
seanrx
x 6
Unread post by seanrx »
Hi.
Requesting the part nos of a coil pack please.
Vin: VF7**************[VIN obfuscated, can be read by forum staff]
x 6919
Item (2), Coil Pack (inc. 4 extensions) (3), part: 9656695780, £229.33 inc. VAT from Citroen.
kuhar
x 3
Unread post by kuhar »
Hello,
I would like to know what kind of head lights my Citroen C4 GP has (and part number of course).
Thank you
- Marko
x 6919
You have Halogen lights Marko
(1) Complete Headlamp
Left, part: 9677217380, £396.80
Right, part: 9677217280. £396.80
