A good example of where this all goes wrong: https://www.ebay.co.uk/itm/265800338699
- x 6665
- Donor 2023
- x 1466
Which doesn't really help Husky. With the flywheel in question, is it or is it not a solid flywheel?
- x 6665
PSA sometimes state whether it's a DMF (but not always and some can look like the one pictured but actually be a DMF), but as it was not mentioned, neither did I so as not to add to the confusion. Best for Husky to check with his dealer if unsure.
- x 1195
Pretty sure that's a solid flywheel, it usually says Dual flywheel if it's DMF, and it certainly shows a clutch with springs for a SMF rather than a solid plate for a DMF. The one Marc linked on eBay is a solid flywheel, despite what it says! There are always exceptions of course... Will only know for sure once it is out.
- x 508
3 ebay sellers confirmed solid, its a 1.4 so id think it wouldn't vibrate as much as a 1.6hdi, my old 206cc was dmf but i did the conversion tbh it drove the same, they last longer too
Husky. Thinking outside of the box is better than sitting in a dark one.
- x 240
Hi Marc, can you give me the part numbers for rear brake hoses for my C5 x7
Darren
- x 6665
OEM Original Rear Brake Hose Left, part: 4806K2, £50.94
Cheaper Hose, part: 1650842280, £27.04
(4) Right Hose
OEM Original Rear Brake Hose Right, part: 4806K3, £55.25
Cheaper Hose, part: 1650842380, £27.04
- x 240
- Donor 2023
- x 12
Could I have the number for camshaft sensor please? VF7**************[VIN obfuscated, can be read by forum staff]
Think I'll take a gamble based on my post here
viewtopic.php?p=782146#p782146
C8 2.2.hdi (6 seat Exc) van/can
207cc 1.6 hdi (project)
Sold/dead
Mk1 Dispatch 06 Face lift - 2.0 HDI - RHZ (sold)
2x xsara picasso 1.6 HDi
2x mk1 C4 Pic and a mk1 C4 GP
1x mk2 C4 Pic
Sold/dead
1x mk2 C4 Pic
- x 6665
(15) Camshaft Position Sensor, (LG 57 BA WHITE), part: 1920ES (No Longer Available from Citroen).
- Donor 2023
- x 12
Thank you Marc
Sold/dead
1x mk2 C4 Pic
Sold/dead
1x mk2 C4 Pic
- x 1703
Good evening,
Could I please have thread sizes for front and rear brake bleed nipples, Peugeot 406 Coupe 2.2 HDi.
It has Brembo calipers on the front, which I think were standard fit at this point (cost engineered back to the Lucas items later in the Coupe's production run I think)
Vin number VF3**************[VIN obfuscated, can be read by forum staff]
Thank you
Thank you
- x 6665
They are not provided Matt, only the complete Caliper fixing screws, but no parts shown for the bleeding nipples.
- x 1703
Thanks for checkingGiveMeABreak wrote: 06 Dec 2023, 11:28 They are not provided Matt, only the complete Caliper fixing screws, but no parts shown for the bleeding nipples.
- Donor 2023
- x 9
Hi Marc
Can I get part number and price for these please?
VR3**************[VIN obfuscated, can be read by forum staff]
The little plastic piece on the end of the bonnet stand
The access hole cover in the RHS boot trim
The top part of the centre console as pictured Cheers
