Magneti Marelli rt 4 problem
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Bibiqn
Re: Magneti Marelli rt 4 problem
Unread post by Bibiqn »
EDC5 wrote: 28 Apr 2018, 17:58
GiveMeABreak wrote: 28 Apr 2018, 14:27 Guys this is probably NOT compatible with the C4 Picasso. That is an older system. The RT4 that went into the C4 Picasso is similar to the RT4 used in the early X7.
Yes, the RT4 in that picture is much larger than the single DIN variant of the RT4.
No problem for size.only i want to work.
EDC5
x 120
Unread post by EDC5 »
Bibiqn wrote: 28 Apr 2018, 18:17
Here is the problem:
Bottom left is the size of RT4 of the C6. It is much larger and wont fit the hole of the normal RT4 (bottom right)
Bibiqn
EDC5 wrote: 28 Apr 2018, 18:37
Yes i saw
But only front panel i thing is much big.The back side i thing is the same size
drumvlado
Unread post by drumvlado »
The front panel/facade is interchangeable and the head unit behind is the same. If you have the old facade, it is a matter of 2 minutes to change them. You can do it without unplugging the head unit from the car, just sliding it forward few centimeters. And this is definitely an RT4 unit. There are 3 types of labels for that - RT3 X3-N3/ RT3ev and RT4. Only the French know why...
Vladimir
