I found this, in which an Australian person personally concluded there was no reason not to tow with, coincidentally for recent discussion here, the KonaMandrake wrote: 05 Dec 2019, 14:50Yes the lack of towing options for EV's thus far is very perplexing. On paper an EV should be the perfect tow car with no clutch to burn up, full torque available from stationary, a smooth and effortless take off, regenerative braking to control the speed downhill without using friction brakes etc...andy5 wrote: 05 Dec 2019, 13:54 Some people want an electric car that can occasionally do towing.
Very little choice. Cars that can easily tow in other versions just don't have any towing weight specified for the electric one.
Yet there are very few that are tow rated even when the ICE versions are. I just don't get it. When they were <100 mile range you could argue that since towing can easily halve the range of a car (including ICE) due to aerodynamics the manufacturers didn't want to tow rate them because buyers would complain about the terrible range while towing...
But now you can get 250 mile range EV's I don't see how that argument holds water any longer, especially if I just want to tow a trailer to the local dump a couple of times a month not for hundreds of miles! EV drivers are starting to get a bit miffed about the stubborn reluctance of manufacturers to tow rate their EV's and what's really behind it...
Also this seems to vary by country - there are some EV's that are tow rated in parts of Europe but are not in the UK when they're the exact same car just with the steering wheel on the other side!![]()
https://thedriven.io/2019/06/10/towing- ... t-be-done/
I put this case to Hyundai and got the following unofficial response from a key person who should know, but who wishes to remain anonymous:
“Technically there is no mechanical issue in towing with any EV, including the Kona. The potential problem one may encounter, especially in the Kona, is the State of Charge on the battery.
“One may get an inaccurate reading of remaining range or charging rate. eg. when one is towing, especially up hill at both extreme ends of the ambient temperature, the range and charge reading will not be true.
“If towing on a flat surface at constant speed then those readings would more likely reflect the “true” reading. Additionally, it is not recommended that you tow more than 500kg.”
So it appears their only concern is that the ‘fuel gauge’ may not give an accurate reading!
_
Plus other interesting comment
I'm not sure about that cutely small caravan though, need to go up to a ton or so
