Rear Suspenders Bump Stop now NFP
x 8119
Re: Rear Suspenders Bump Stop now NFP
Post by CitroJim »
Stickyfinger wrote: (Jim.....no idea how the hell you get the bush out of the ram when it is on the car........given up, have to wait for pipe seals now....grrrrr bad day)
It's all here on my website Sticky :wink:
x 1973
Post by Stickyfinger »
Followed that, but I don't have three hands , to hold ram/operate bush puller....friend down today to assist
x 8119
Post by CitroJim »
One thing to be aware Sticky, is that the original bush is a jolly tight fit in the ram eye, hence needing mandrels or a press to do the job...
x 1973
boy oh boy, do I know that ! :).....its hard with it hanging off and with only two hands and a strap to help keep the swing off the feed pipes ..........I failed...called for help (hate that !)
x 8119
Post by CitroJim »
I turned up one of the mandrels I use on the lathe but if you have a good assortment of sockets and a length of threaded bar and thick washers you'll be fine...
Chris570
x 37
Post by Chris570 »
CitroJim wrote:I turned up one of the mandrels I use on the lathe but if you have a good assortment of sockets and a length of threaded bar and thick washers you'll be fine...
Mine just fell out.
It was knocking a fair bit though ;)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
