My Activa seems to be developing a new problem every week at the moment! Most are little and easily solved but this one has flumoxed me over the weekend and tonight
Over bumps, there is quite a heavy clonking noise from the front end. It is coming from the right hand side of the car and is most pronounced when the right front wheel hits a bump but is also heard when the left hand wheel hits a bump. It is always there in the background though, even over small bumps. There is also a soft clonk when the body is adjusting itself from side to side when stationary.
My immediate thought was that it must be anti-roll bar related but on inspection, everything seems tight with no play. I've also ruled out any problems with steering linkages. All seems in really good nick.
Found some loose bits and pieces such as the washer fluid filler neck and the panel under the washer bottle that bridges the gap between the bumper and the wheelarch. These are now also firmly in place and the clonking remains!
Has anyone had any experience of this? Maybe I'm not checking the suspension or steering properly?
Thanks,
WAINY.
