I am new to this forum and French cars in general, having recently splashed out the princely sum of £450 for a '98 406 1.9td with 136k on the clock. My last few cars have been old Merc diesels, but after the last beast (w124 estate, what a motor!) bit the dust at MOT time I decided to just get something cheap and diesel, and this 406 came up. I know the XUD9 is very well thought of, almost as good as an old Merc lump... 8)
Anyway, a few things things are worrying me, a few things I'm just curious about. In no particular order:
1) There are three plugs just dangling around under the bonnet, I can't see anything obvious that they connect to.
This one has 3 wires going to it, and is around the Injection Pump. Something to do with an immobiliser?
This 'un has two wires, and also comes from the loom near the IP (sorry for the extreme close up!)
Then there's this 3 wire one...
2) The engine electronics warning light is always on, is this linked to 1)?
3) When you take your foot off of the throttle, the rev counter falls to zero, coming back when you press the pedal again. Linked to 1) and 2)?
4) The Bowden cable coming from this vacuum device isn't connected to anything, again, I couldn't see anything glaringly obvious as to where it should go. Is this a vacuum operated actuator, or a cable operated vacuum valve? (ie does the vacuum pull the cable, or does pulling the cable switch/dump vacuum?)
5) When you first start driving, the brake pedal is extremely stiff and you really, really have to stand on the pedal to get the car to stop. I'm guessing this is because there's no servo assistance. After a short while the brakes are normal. Could this be a dodgy vacuum pump? Dodgy servo? Or something to do with 4)?
6) This has only happened once, but was quite unnerving; whilst slowly going around a big roundabout at rush hour, my OSF wheel locked up! I stopped the car and got out to check the wheel hadn't fallen of (it hadn't), then ever so slowly limped off to get out the way. Within 20 yards or so it seemed fine and it hasn't happened again. It is very worrying though, I'm scared it will happen at 70 on the motorway! Could this be an ABS problem, or something to do with 5)?
7) Smoking! The car produces a lot of blueish/grey smoke, but only after 5-10 miles of 50mph+ driving. Then sometimes it will just about vanish, then come back again. It doesn't smoke at all from cold, and engine load doesn't have a huge affect on it. The oil level is spot on. I have thought about disconnecting the crankcase breather from the intake line and taking it for a spin and watching for smoke, is this a good idea?
8) There is an oil leak around injector 3 (counting from the O/S). Could this oil also be getting in to the combustion chamber and causing the smoke? The engine doesn't run on. What kind of seal is under the injector? Is it easy enough to change?
9) There's a clunk from the OSF when you go over bumps, I'm guessing it's a droplink; are they easy to change?
10) Has anyone actually read this far?
Blimey!
Sorry for such a long first post, but I'll be extremely grateful for any advice anyone can offer!
Cheers!
Hibbo
