This was another example of what exactly/how much a Lexia can do on a car is totally dependant upon what version of software is being used on the particular car, each one is an individual with seemingly it's own personality
Today was spent on a second Xantia diagnosing an ongoing ABS saga where the owner has lost count of the number of sensors that have been replaced plus diagnose an airbag fault.
Lexia revealed that yet again the N/S/R ABS sensor was shown as being faulty but as it had been replaced twice in the past two years by a local garage I was rather suspicious as to whether I was being given a red herring, so I used Lexia and my Sykes ACR4 diagnostic tools in "parameter readings" to observe the road speed being recorded by each of the four wheels as the car was being driven. The strange thing that came up then was that both rear sensors displayed 0.0 km/h whereas the front two were 93 km/h and 56 km/h both when the vehicle was stationary and when in motion. Bearing in mind the history of the number of ABS sensors that had been replaced I was rather suspicious that maybe the ABS ECU/block may be faulty so I substituted both of these and but the readings remained the same.
A pinout test at the ECU end revealed that the N/S/R sensor had a high resistance of 1453 ohm's rather than a more normal 1098 so I went to test the sensor directly and discovered that it was last replaced the cable had been re-routed and not supported very well which probably led to it's early demise. Luckily I had a new replacement sensor in stock but when I came to fit it I could see why the previous one had been fitted differently from the original fitment as trying to route the cable up through the subframe proved all but impossible as the suspension arm obstructed the plug even after I lowered the subfame for improved access. As the car is an estate (they use larger suspension arms) I presume that unless you remove the suspension arm for improved access between the arm and subframe it must be all but impossible to pull the cable through. Rather than waste more time I used an alternative route to the original spec and the previous fitment and supported it at numerous locations using wide cable ties.
The Airbag fault was diagnosed by Lexia as being down to the "Drivers Module", digging into my Citroen dealer specialist tools I plugged in a airbag tester into the loom prior to the steering wheel connection and discovered that the fault then cleared so swapped the steering wheel ring and bingo fault cured and one very happy owner
Good news on my back as it's improving day by day, hopefully I haven't overdone it again after my tinkering today.
