- Oil and filter change
- Change fuel and air filter
- LHM change
- Clean up and re seal underside of strut top mounts
- Clean up N/S/R brake line and hammerite
- Remove, clean and re fit rear and front height correctors
- Clean off rust spots on exhaust and high temp paint seal them
- Find duff glow plug and replace
- Check leak off lines
- Clean up and re seal wheel arches
- Re seal scuttle seal
- Nourish all window seals
- Remove and re fit front fog lamp
- Check all 4 wheel hubs, clean and re grease bolts and threads
Once that lots done then i shall feel alot better
