Peugeot Boxer 1.9d Problem
Bolt34
Re: Peugeot Boxer 1.9d Problem
Do you have egr valve??
Bolt34
ie, vacuum controlled throttle body on the inlet manifold??
doggone1
Yes vacuum egr but seems to be working fine
Bolt34
Is it holding the throttle body closed when trying to start and on tick over.. if so pull off the vacuum pipe to the Throttle body and try to start again.. only a thought…
