If you can wait until the next time we're up your way we can do it for youmyglaren wrote: 04 Sep 2023, 11:19 Back to being likely to make a dogs dinner of measuring it.
"If it can go wrong, it will"!
- x 8422
Re: Citrojim's AX, Saxo, Pixo, C3, Running and Cycling Tales
- x 5674
Ta. I will no doubt rediscover it while looking for something completely different.
It is very awkward to get to it to measure.
- x 5674
Found it, right where it should have been
Looks rather sorry for itself and I am sure it pre-dates the acid attack.
- x 8422
That's well worn Steve, but you'd be amazed at how long they can soldier on... I'd hate to think what the ones on my compressor and bench grinder look like. Or on my lathe one for that matter!
- x 8141
Yes that certainly has seen better days Steve, but on the plus side it looks good enough for the dealer to be able to match it up!! Good luck with that!
- x 5674
Probably later this week.
I became a "Red Rubber Grease" tycoon as a result of a visit to mine! See here...CitroJim wrote: 04 Sep 2023, 10:41 All sorts of belts were what the old agricultural supplies shops used to deal in. Once, every town had one. Now an endangered species... I miss them.
viewtopic.php?p=768303#p768303
- x 8422
Yes, as I fondly recall how both those and ironmongers used to be... The latter I really do miss... It used to be so good when you could get just one tap washer without having to buy a blister pack of 50 assorted for just the one you need, knowing the other 49 are so esoteric you'll never need them, everNewcastleFalcon wrote: 04 Sep 2023, 17:49I became a "Red Rubber Grease" tycoon as a result of a visit to mine! See here...CitroJim wrote: 04 Sep 2023, 10:41 All sorts of belts were what the old agricultural supplies shops used to deal in. Once, every town had one. Now an endangered species... I miss them.
- x 8422
My new front door
All window and door fitting now completed to a very high standard
Very pleased...
And Mick and I got stuck into kitchen wrecking in readiness for the new one to be fitted
Whilst the electrician commenced lots of work to bring my wiring up to current regs. and add many, many more sockets...
No more 4-way extensions will be permitted in the house from now on...
Polly did a great job as a van to ferry bits of old kitchen to the tip... She's a superbly versatile vehicle
Huge thanks to Mick for some absolutely superb work yesterday
Skull
- (Donor 2026)
- x 382
Love a bit of kitchen demo work
Gary
Gary
- x 3565
I do hope your new kitchen has been planned in order to maximise the production of flapjacks. To fail on that would be a dereliction of duty
- x 3296
Wot he sez!bobins wrote: 06 Sep 2023, 06:58 I do hope your new kitchen has been planned in order to maximise the production of flapjacks. To fail on that would be a dereliction of duty![]()
- x 8422
Definitely, and for the refreshment of visiting FCF'ersHell Razor5543 wrote: 06 Sep 2023, 07:31Wot he sez!bobins wrote: 06 Sep 2023, 06:58 I do hope your new kitchen has been planned in order to maximise the production of flapjacks. To fail on that would be a dereliction of duty![]()
- x 8422
I should add that the kitchen design is all Mick the Maverick's work so the above needs were very much taken into account
- x 8141
Jim has failed to mention the 30 year old treasure we found while demolishing the kitchen, while my head was inside a base unit to undo the worktop fixings, I noticed a metallic knob above me emerging from the top of the unit's side panel under the work top!!
Further investigation revealed what?
Hopefully Jim will provide a picture later but a few guesses in the meantime might be amusing!!
While I'm on the subject thanks to Chris570 for his assistance on the arduous tasks in progress when he called in!!
