Electrican help please? Citroen C4GP ABS wiring mare (fixed)
x 6956
Re: Electrican help please? Citroen C4GP ABS wiring mare (fixed)
misho_fte wrote: 28 Jan 2021, 21:13 I understand. Can you provide for my VIN the ABS/ESP and handbrake computer diagram connection with BSI?
Here you go:
Most of the component codes are listed on the wiki here and are in ascending order:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
Location of Relevant Systems / Harnesses
Vlada33
Unread post by Vlada33 »
The vin is already posted, here goes again
Vin number VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
hello,I already posted on this topic,but now have some other problem abs,esp,parking brake,polution light and spedoo is showing two dashes and not the speed.diagnose check is showing that ABS has problem with the comunication,didn't write down codes,i can check it in the morning if that will help (its visible on other sistems where fault is somehow connected with the abs) but ABS modul cant be read...like its dead or disconected,so I think that is possible that abs modul is lost power or ground?
so I come here to ask for abs/esp diagram (i suppose that diagrams are diferent from car to car so I reapeted my vin number...
thanks in advance
Vlada33
Also, if anyone can tell me which wire are CAN from the abs/esp modul...
I check all wires (looking at the diagrams posted here) and I have 12v and grounds, also I try used abs/esp modul and still have same problem,no communication... Maybe is CAN wire break somewhere
Laxon
(Donor 2026)
Unread post by Laxon »
Vlada33 wrote: 18 Feb 2022, 12:28 Also, if anyone can tell me which wire are CAN from the abs/esp modul...
Hi Vlada.
Did you solve the problem?
/Laxon
Deimos
Unread post by Deimos »
Good day. Is this topic still in use? I'm in urgent need of wiring diagram for ABS unit and it's connection to other modules. Also I need an ABS unit socket pin out. Citroen C4 picasso 2013 diesel
x 8085
Deimos wrote: 08 Oct 2025, 05:45 Good day. Is this topic still in use? I'm in urgent need of wiring diagram for ABS unit and it's connection to other modules. Also I need an ABS unit socket pin out. Citroen C4 picasso 2013 diesel
Which engine do you have as the wiring may vary, and what is your rpo number as that is needed to find the correct diagram.?
x 1450
Unread post by xantia_v6 »
For this one we may require the VIN
Deimos
mickthemaverick wrote: 08 Oct 2025, 06:39
I think this is the engine model 9HR (DV6C). rpo number: 13258FV. VIN: VF7**************[VIN obfuscated, can be read by forum staff]
x 1450
I am not sure that we have diagrams for this, but does it have ESP/Stability control?
Deimos
xantia_v6 wrote: 09 Oct 2025, 07:36 I am not sure that we have diagrams for this, but does it have ESP/Stability control?
Yes, it does. Also, if it helps, it's a Bosh ABS unit with a 36-pin connector.
