"THE CXM" RETURNS AS THE CHEVRONS RALLY SEPT 2015!
A place to discuss any upcoming meets, club rallies and general get togethers.
Fake Concern
x 65
Re: "THE CXM" RETURNS AS THE CHEVRONS RALLY SEPT 2015!
Unread post by Fake Concern »
CitroJim wrote:
Fake Concern wrote:Really nice to see every one here today & thanks SO much for all the help with various things. Some problems haven't gone away & I'll be asking questions later. I'll post some pictures when I've had a chance to look at them all.
That's a georgeous XM you have there Fake :-D 8-)
Did the engine run ok on the way home?
Hope the diode mod fixes the Hydractive fault but if it doesn't, don't worry, we can sort it :wink:
Jim, thanks & thanks for the help. It was weird on the way home, it didn't stall & was fine when under load and when on a trailing throttle, but with the throttle feathered trying to keep a constant speed, it felt like the gas kept switching on & off & lurching unpleasantly. It did this until nearly up to Brighton then the EML came on & the symptoms changed, not lurching, but not revving smoothly felt like it was missing. I'll try the Lambda sensor first as we know that is faulty.
By the way love the photos & I'm quite jealous of the bike!
x 8411
I'd be inclined to recheck that vacuum pipe to the MAP sensor, especially the tube downwind of the joint... That pipe must be 100% good and I remember well the same set-up causing much the same issues on Pug 205s... It only took a little split/pinhole..
Also, pop the MAP sensor off and check its inlet is clear. I've seen them bunged up with a bit of oily clag before now...
Swapping the Lambda sensor will be good.. Get a decent one. I find the el-cheapo eBay offerings can be very short-lived...
Fake Concern
x 65
CitroJim wrote:I'd be inclined to recheck that vacuum pipe to the MAP sensor, especially the tube downwind of the joint... That pipe must be 100% good and I remember well the same set-up causing much the same issues on Pug 205s... It only took a little split/pinhole..
Thanks for the advice, I'll have a look when I get in early enough one evening. Seen lambda sensor in Euro for not too silly money.
citroenesque
x 4
Unread post by citroenesque »
NEXT YEAR:
1997 Citroen Saxo SX 1.6i Auto, Fijian blue, 60k mls
2004 Citroen C5 Exclusive SE 3.0 V6 Auto. Silver. 114k mls
2006 Citroen Xsara Picasso Desire 1.6 16v, Sahara bivouac (beige). 128k mls
2008 Citroen C1 Vibe, red. 74k mls
x 8411
citroenesque wrote:NEXT YEAR:
Excellent :-D Looking forward to it already!
