x 6948
You'll have to let me know which items you want, but (9) is the Injector Seal, part: 1609848280, £4.10 each.
Huskyxantia
x 928
Unread post by Huskyxantia »
Im needing as follows 7,12,8,9,11 do i need 13 whats number 13 ?
Thanks marc
:-D
x 6948
(7) Engine Injector Seal:
OEM part: 1610564580, £3.89
Set of 4 Inj. Repair washers Part: 198173, £13.10
(8) Engine Injector Protector
OEM Part: 1609848080, £5.64
(9) Engine Injector Seal
OEM Part: 1609848280, £4.10
(11) Injection Holder Clamp Pillar Screw
OEM Part: 198283, £2.83
(12) Injector Holder Fixing Nut
OEM Part: 198263, £2.80
(13) Circlip
OEM Part: 1609848880, £0.42
Huskyxantia
x 928
Thanks marc ,I take it 13 locks the injector in place
:-D
x 6948
You should see the groove for it on the injector.
jordyh
x 4
Unread post by jordyh »
Could I please have the part number for the steering rack for a B78 C4 Picasso VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks in advance.
x 6948
Item (1)
OEM part: 16 463 470 80, £1798,.74
Exchange Part: 16 741 387 80, £1755.89
Huskyxantia
x 928
Is there wire ring exhaust gasket for a 206cc 1.6hdi that fits the outlet of the turbo to the dpf ? As i have noticed exhaust gasses from the clamp , if so could i have the part number ?
:-D
x 6948
This is the catalytic converter - anything on here let me know.
These it the turbo and oil return parts
cs101
x 6
Unread post by cs101 »
GiveMeABreak wrote: 24 Sep 2022, 15:28
cs101 wrote: 24 Sep 2022, 15:19 Please can I get the following part number for my van. VIN VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].
1.Front complete Bumper without fog lights.
2. Front Nearside Wing Panel.
3. Steering Reservoir (Where the steering fluid goes)
Thanks.
Bumper
If you require any other item, just let me know the number from the diagram.
Item (1) part: 1615649280, £623.92
Wing
Item (1), Part: 9808757880, £385.88
Power Steering
Electric Pump Item (1), 1679831980, £905.89
It appears the reservoir is integral to the Power Steering Electric Pump.
Hi! Please can you give me the Part numbers and prices for the items 3,7,9,10 under the WING Diagram
x 6948
Here you go:
These parts are all for the LEFT wing:
(3) Front Wing Inner Frame, Part: 1613841280, £503.51
(7) Front Wheel Arch, Part: 1613942880, £586.12
(9) Passenger Compartment Strengthener, Part: 1614299980, £342.18
(10) Wheel Housing Mudguard, Part: 9808363580, £136.40
All VAT inclusive direct from Peugeot.
cs101
x 6
Thanks Marc.
Huskyxantia
x 928
GiveMeABreak wrote: 03 Oct 2022, 17:40 This is the catalytic converter - anything on here let me know.
Clamp no.10 , i reckon my ones give up the ghost.
Cheers marc, also inlet manifold seals ? Can oil leak pass these when they fail ? , have you part numbers for these many thanks.
:-D
x 6948
(10) Exhaust System Fixing Clamp, part: 171360, £14.81
(2) Exhaust Manifold Gasket, part: 0349N0, £6.49 (in case you need this).
Air Intake
They do the complete Intake distributor (1) that includes all the seals and the distributor, or the seals independently.
(1) Intake Distributor Kit & Seals, part: 0361N3, £375.28
(3) Air Distributor Seal (DIAM INT35 TORE 6,25), part: 0348R4, £7.27
(4) Air Distributor Seal (DIAM INT29,5TORE6,25), part: 0348R5, £7.27
(5) Air Distributor Seal, part: 0348S5, £7.58
Huskyxantia
x 928
Great job marc , many thanks
:-D
