Merged Lexia & Diagbox threads
x 6955
Re: Merged Lexia & Diagbox threads
Don't know what you've bought here these are discs that could have anything on them. You should be using Diagbox software that incorporates both Lexia and Planet Peugeot. The system will run whatever is appropriate for your vehicle. Can't comment on this as you've bought kit from a supplier we don't know and it could have anything on . I'd be more concerned about the hardware you have and whether it has the full chips and resistor on board needed for some c5 and Peugeot vehicles. Also what revision have you bought?
Fake Concern
x 65
Unread post by Fake Concern »
Don't know, I got it cheap from someone on C4 owners who now has a DS4. I know it worked with his VTS & at the time that was all I had!
vborovic
Locked user account
x 40
Unread post by vborovic »
The hardware, at least from the PSA Part no should be ok ... 9780.Z5 (if I read correctly from the provided photo)
cachaciero
x 9
Unread post by cachaciero »
GiveMeABreak wrote:Hi Harry - "Confused - you will be" (!) :-D. Here I'm referencing Service Docs (DocBackup & SEDRE) and the fact that you and a few others are having DVD install issues. So in response to Richard, I'm offering to uploa
http://www.slysoft.com/en/virtual-clonedrive.html
Gone no longer there :-(
Try http://download.cnet.com/Virtual-CloneD ... 73879.html
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
x 6955
I took the links down after a while Tony. If you want to download the files just let me know and I'll get them back up tomorrow after I'm back from town probably just after lunch.
old son
Unread post by old son »
I don't know if this is the right place to ask this question but here goes. Can anybody with a Lexia who lives in the Bexleyheath, Kent area turn on the cruise control on my 2010 Berlingo Multispace?
x 6955
old son wrote:I don't know if this is the right place to ask this question but here goes. Can anybody with a Lexia who lives in the Bexleyheath, Kent area turn on the cruise control on my 2010 Berlingo Multispace?
Hi - click on this link and it will take you to the list of members and their locations with a Lexia. If you find one near you, send them a Private Message (their usernames are shown for you) and hopefully you'll get a response. :-D
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
old son
Thanks for your response. I have PM'd two of the names but no response.
vborovic
Locked user account
x 40
Some members aren't active on a hourly basis ...
Xantippa
x 29
Unread post by Xantippa »
Any hint how to reset battery setting with Diagbox after changing battery on C5 X7? I changed battery two years ago without any diagnostic tool, and have been suffering economy mode since that. When I go to battery test with diagbox, it tells I should have some battery testing tool. Is it possible still tell that battery has been changed? Battery size is set right. Battery voltage is good when measured, and I haven't had any problem with starting even on very cold conditions.
old son
vborovic wrote:Some members aren't active on a hourly basis ...
I appreciate that. It's why I waited a week before mailing here.
x 3566
Xantippa wrote:Any hint how to reset battery setting with Diagbox after changing battery on C5 X7? I changed battery two years ago without any diagnostic tool, and have been suffering economy mode since that. When I go to battery test with diagbox, it tells I should have some battery testing tool. Is it possible still tell that battery has been changed? Battery size is set right. Battery voltage is good when measured, and I haven't had any problem with starting even on very cold conditions.
There is a way to test the battery with Diagbox without using a Midtronics tester as I've done it before now - I can't remember how you get to the option to do so, but it's not too difficult to do it as I've managed it :-D Part of the testing process is to go through a series of 'lights on for two minutes', 'ignition on', 'ignition off', etc, etc.
I think the device that actually measures battery condition and that provokes the economy mode is actually mounted on the battery terminals - at least it is on mine !
x 6955
It would be great if you could bribe the grey cells, as I too was hunting about for this damned procedure. I put a brand new Varta AGM with a higher crank rating on the X7 as soon as I got her as I wanted peace of mind. That, and with all the kit on there I wanted to ensure it was never going to let me down. However the damned Economy mode comes on after 3 minutes REGARDLESS of how long the previous journey was, so I'm not accepting that it gives you an amount of battery time wth engine off according to how long you have continuously just driven! I had a good look around Diagbox and cannot see the option anywhere to tell it I have a nice new battery and the amps etc., so it probably still thinks I have the old battery on and is being UBER cautious! If you can remember anything about the procedure please let us know. Can you confirm it was Diagbox that you were using and also your X7?
x 3302
I do not know if this would help, but I know that, on my C5, there is an option in one of the configuration menus to change the Economy Mode delay. I wonder if, sometime in the past, it was set to 3 minutes (instead of the 30 minute default). Next time I pop the Lexia onto her I will look for where this is (but my C5 is a Mk1).
x 5670
I think the X7s are different James. Mind of their own.
