Merged Lexia & Diagbox threads
x 3306
Re: Merged Lexia & Diagbox threads
Now that is of interest. My Lexia is running 7.15, as when I run 7.16 it locks up (activation issues), and I would want to remain current if possible.
x 6957
GiveMeABreak wrote:Richard - I think I have space on my MEGA account, so if you can wait for me to upload the ISOs (anything up to 21GB!) I'll make them available for a week or so for anyone. Let me know first :wink:
Update: It's taken all weekend - MEGA were having some issues again, so 2 upload failures later we are nearly there! Disks 2&3 compete and halfway through Disk1. I'll post back tomorrow (later today I mean as I've just looked at the clock!) when complete.
Update2: All completed - Harry & Ricahrd PM'd with links.
If anyone else wants the ServiceBox ISOs (1, 2 & 3), send me a PM.
harryp
(Donor 2022)
x 73
Unread post by harryp »
Wow, much midnight oil. Many, many thanks Marc =D> . Will get to it in an hour, or so I hope. On an allied topic, managed to get Diagbox loaded ok at the 5th attempt. Yet to check it on the vehicles, but I'm hopeful!! One crossed off for now :wink: . Thanks for all your not inconsiderable input :-D :-D .
Regards
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
Sloppysod
x 393
Unread post by Sloppysod »
GiveMeABreak wrote:Don't buy it Sloppy,........
Stu
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6957
I've got the cleaner for Diagbox that'll tidy up the registry and delete the directories if you want to do a clean install. I'm out with the C3 for MOT but will be home later, send me a PM Stu for what you need.
x 6957
For those interested, here is a link to a separate Thread concerning the Diagbox software change logs - all is explained in the post, but Steve thought a mention here too for those buried in the main thread wouldn't go amiss :wink:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=54329
x 6957
Just a little Diagbox install Tip - for those that have performed a clean install of Diagbox on their Laptops and have applied their chosen updates: when you first plug in your hardware to the USB port, wait until it installs the drivers (this can take anything up to 4-5 minutes in some cases), then remove the USB cable and plug it into each USB port on your laptop / PC in turn and let the drivers install on each port you have. This will avoid any issues when you come to use the device in your vehicle and plug it into a different USB port. :-D
Also, you should connect the hardware to your laptop first, run Diagbox and then connect the interface to your vehicle's diagnostic port when asked.
harryp
(Donor 2022)
x 73
Marc, PM sent.
Regards, Harry
harryp
(Donor 2022)
x 73
Ref Diagbox...
Marc wrote...
""and if you have WIFI, make sure it is switched on and working. Diagbox needs to have these on to work (just don't update from the internet if it asks).""
Does it actually to see the Internet, or just the interface card as previously, i.e.not connected
Regards, Harry
x 6957
The card should be 'enabled' - i.e. not disabled in your Device Manager. It doesn't need the Internet for installing, but it will need your network card hardware working in order generate a unique code for your PC.
harryp
(Donor 2022)
x 73
Great, as per previously :-D
Regards, Harry
harryp
(Donor 2022)
x 73
Pm sent
Regards, Harry
Almo2015
Unread post by Almo2015 »
Hi @Givemeabreak could I have the service box iso please? Thanks Sean :)
harryp
(Donor 2022)
x 73
Many thanks to Marc for his dedication. =D> =D> =D> .
Is anyone else getting the "" fatal error the installed application is out of date, please update it.""
The system loads very easily off Marcs Disc Images as I am on the 3rd reload!!
The phantom *.dll's are loaded. (Also mentioned in MMHAuto and various Peugeot threads), but still haven't got to the bottom of it yet. Yes it has been uninstalled, system cleaned, re-booted and re-installed, but to no avail. Seems very odd to me. Running Win7 32bit, latest Java, Explorer set to default browser, but no go ](*,) yet again.
I am wondering if the message means what it says, as per so many computer error msg's - which application I wonder?
Regards, Harry
x 6957
Harry did you copy the 'infos' file over? Needs to go in 2 places. PM me if you want me to dial in and sort this for you.
