How to Replace the Internal MicroSD Card - RT6
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
Helder Lopes
Re: How to Replace the Internal MicroSD Card - RT6
Unread post by Helder Lopes »
You need to install the v2.86 Firmware by PEN...
You must format PEN in FAT32 in a Windows 7 PC cause Windows 10 and 11 hide 2 files in the PEN and the system refuses to install!
Better you use a PEN with activity led to check the progress in the car.
Car with the engine running!
Insert the PEN and wait!
After CD motor runs, the LED on the PEN will flash for about 5 to 7 minutes... LCD is dark with some poor visible bacl light, only seen in darker places or at night!
After that time 5 to 7 minutes, the led will stop flashing and in abaout 1 minute you will see DISK CHECK on the LCD!
Update started!
The system will do some updates and may restart some times during the process...
Some steps are:
CRC Media Checking
FP upgrade 0- 100%
Partition process on MicroSd card...
Upgrade Preparation... (freezing for about 3 to 5 min. is normal)
Loading CRC 0-100%
Loading 0-100%
System reboot in 5 secs...
System reboots in 1 to 2 minutes with black screen then it switches on and recovery is done!
Now you need to configure and calibrate the system to your VIN and model... Beep is heard until you configure the VIN...
Then you can install Maps and Radar files... First you must install one map and then radars... The system will restart when first map is installed and you remove the PEN from USB port...
I can make configuration and calibration files (Bluetooth echo correction etc) for all PSA models and send it to you.
Install it is very easy. 1 or 2 minutes!
If you want, contact me by the Portuguese "FORUM PEUGEOT PORTUGAL" where you can get full details, maps, radar files and more!
Natasa 007
Unread post by Natasa 007 »
Hello everyone,
I've replaced the faulty SD card in my Citroën RT6 (eMyWay) and now I'm looking for the correct Virgin SD image to get it running again.
Could someone please share a link to the file or send it to me via PM?
Many thanks in advance for your help!
x 1938
Unread post by Paul-R »
Did you download your RT6's configuration using Mirascript before taking your old SD card out?
Natasa 007
Hello everyone,
I’ve replaced the faulty micro?SD card in my Citroën RT6 (eMyWay) unit, but the system is completely dead (black screen, no reaction).
I understand that in this case I need the Virgin RT6 SD image to get the unit to boot before I can apply the firmware update.
Could someone please send me a link to the correct Virgin RT6 SD image for my system?
My VIN is: VF7**************[VIN obfuscated, can be read by forum staff].
Natasa 007
yes, i did use a Mirascript
x 1938
If the screen is completely black then you won't be able to upload the firmware or Mirascript configuration as you won't be able to choose options.
Can you put the old SD card back temporarily to see if the screen now works? Then we might be able to go from there.
Natasa 007
The screen does not work.
x 1938
Yes we know that. But was it working with the old card in?
Natasa 007
I put the old Micro SD in start the engine and wait for 5 min, but nothing happend. The screen was black.
What should i do now?
x 1938
Did the screen use to work with the old card?
Natasa 007
No, thats my problem. 3 days ago , when i start my car, screed didnt show, radio didn work, nothing. So i saw on this forum, i need to replace sd card and instal new firmware on rt6. I went thru the procedure on the first page...
x 1938
OK, so the real problem is that the screen stopped displaying, not that the SD card itself went faulty.
If the screen was black and not displaying, how did you manage to run the Mirascript program?
Natasa 007
Just following up on my previous request — my RT6 unit is still completely dead after replacing the micro?SD card, so I cannot run the firmware update.
I understand that I need the Virgin RT6 SD image for my unit (Citroën C5, VIN: VF7**************[VIN obfuscated, can be read by forum staff]) to get it to boot again.
If anyone could kindly share the Virgin SD image link with me via PM, I would be very grateful.
Thank you again for your time and help!
Natasa 007
"If the screen was black and not displaying, how did you manage to run the Mirascript program?"
Sorry, i didnt understand what you are asking me. I meant, i have the Mirascript program on my USB stick, but i didnt run it on the rt6.
x 1938
So if you didn't run the Mirascript program then you haven't downloaded the configuration. Are you sure that the card is in need of replacement? It sounds like there might be something else at fault. I can supply you with a link to firmware files but I don't know whether it'll do you any good. I don't suppose you know what firmware the RT6 currently has fitted?
