2015 C4 Picasso alarm/BSI problem
Newpicman
x 3
Re: 2015 C4 Picasso alarm/BSI problem
Unread post by Newpicman »
Newpicman wrote: 25 Mar 2024, 19:16
waj1234 wrote: 25 Mar 2024, 19:00 It's under the plastic panel below the wiper arms. It can be got to but just removing screws if I remember and forcing it open and putting something in to wedge it open while undoing one bolt and one connector. Otherwise it's removing both wipers which needs pullers to do it. My panel went down again ok once I got module out
Mine is the MK2 C4 Picasso, (65 plate)not the grand picasso, any idea if it's the same part number?
Thanks.
Nice 1, thank you.
waj1234
Unread post by waj1234 »
Mine is also a 65 plate standard picasso. Not sure on part number of the alarm module but this is the battery pack I bought. Once you take module out and force it open which takes some doing. Once open there is a code number on the battery pack so you can search for one. The one on eBay is the closest thing to it. https://www.ebay.co.uk/itm/295916330434 ... media=COPY
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 16:28 Mine is also a 65 plate standard picasso. Not sure on part number of the alarm module but this is the battery pack I bought. Once you take module out and force it open which takes some doing. Once open there is a code number on the battery pack so you can search for one. The one on eBay is the closest thing to it. https://www.ebay.co.uk/itm/295916330434 ... media=COPY
Was going to just buy the full alarm module off eBay, plug and play hopefully the easiest way something like this if it is the correct one.
Thanks again.
https://www.ebay.co.uk/itm/144981406236 ... media=COPY
waj1234
No that's not it. That's the internal one. I tried that first and didn't work
waj1234
https://www.ebay.co.uk/p/28012199717
That's one. Part number is
SIRENE ALARME
9677756080 IND: 01
ALM-SIR- CEMOO
DELPHI
INDDEL: D
That one will be used on eBay so pointless getting it. Needs to be new so battery is new.
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 17:01 https://www.ebay.co.uk/p/28012199717
SIRENE ALARME
9677756080 IND: 01
ALM-SIR- CEMOO
DELPHI
INDDEL: D
Thanks, so the battery is in the siren and this is located under the scuttle tray? Surely if I can get a newer one than mine battery should be better.
waj1234
Possibly but you also take the risk of it being dead or a low capacity. Worth a shot I suppose. Even brand new could have been on a shelf ages and the batteries lost charge so may still give an error alarm until charged etc.
waj1234
The battery is in the siren module under the scuttle yes, around center.
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 17:35 The battery is in the siren module under the scuttle yes, around center.
Many thanks for your replies, much appreciated.
waj1234
No problem.
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 17:39No problem.
Think this is the 1
https://www.ebay.co.uk/itm/314697003487 ... media=COPY
waj1234
Mine did not look like that one. It was identical to the first one I posted. That one says grand picasso.
If I was you I would remove yours first and check before buying. The car works perfect without it and obviously no alarms going off so sort of fixes it anyhow lol.
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 17:53 Mine did not look like that one. It was identical to the first one I posted. That one says grand picasso.
Yeah will do that, think it might be same siren on a different mounting.
waj1234
Let me know how you get on.
Newpicman
x 3
waj1234 wrote: 27 Mar 2024, 18:07 Let me know how you get on.
Will do cheers
