Posting photos.
Forum News, Announcements and any issues you're having with the forum
x 8321
Re: Posting photos.
elma wrote: 30 Jun 2017, 08:39 :rofl2:
By far the most satisfying way to deal with computer issues.
Precisely :-D :twisted: :lol:
x 3566
Re: Posting photos.
Further to the issues I was having posting large images.......
This is the error I was getting:
Own work
Own work
but looking at the info / EXIF for that image, I assume it fails on image size (Mb)
Own work
Own work
x 1438
Re: Posting photos.
Unread post by xantia_v6 »
No, it is not failing on image size, it may be having the same problem as MikeT's pictures. If you email the file, I will investigate.
x 3566
Re: Posting photos.
I tried emailing it across about 20 minutes ago, but it bounced back : "message size 5273150 exceeds size limit 5120000 of server"
But.... I opened the image in my usual image software, just did a 'Save as' and changed the filename, and it's uploaded fine below:
Own work
Own work
Own work
Own work
I've checked the actual EXIF info for both the non working and working images and they are identical (as you'd expect).
Exif posted below for info:
ImageWidth - 4128
ImageLength - 2322
Make - samsung
Model - SM-A310F
Orientation - Top left
XResolution - 72
YResolution - 72
ResolutionUnit - Inch
Software - A310FXXU3BQC2
DateTime - 2017:06:18 11:50:46
YCbCrPositioning - Centered
ExifOffset - 226
ExposureTime - 1/100 seconds
FNumber - 1.90
ExposureProgram - Normal program
ISOSpeedRatings - 64
ExifVersion - 0220
DateTimeOriginal - 2017:06:18 11:50:46
DateTimeDigitized - 2017:06:18 11:50:46
ShutterSpeedValue - 1/100 seconds
ApertureValue - F 1.90
BrightnessValue - 4.05
ExposureBiasValue - 0.00
MaxApertureValue - F 1.90
MeteringMode - Center weighted average
Flash - Not fired
FocalLength - 3.70 mm
UserComment -
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 4128
ExifImageHeight - 2322
ExposureMode - Auto
White Balance - Auto
FocalLengthIn35mmFilm - 28 mm
SceneCaptureType - Standard
Maker Note (Vendor): -
Thumbnail: -
ImageWidth - 512
ImageLength - 288
Compression - 6 (JPG)
XResolution - 72
YResolution - 72
JpegIFOffset - 928
JpegIFByteCount - 17499
x 1438
Re: Posting photos.
It is good that you got your image to post.
I have found that there is a bug fix in the exif handling library that the forum uses, and (at least for MikeTs files), the problem is gone in the release candidate for the next version of phpBB. I can't give a date for when we will be installing the next version (which is only a minor update release), but it would probably be in one or two months time.
I have now been able to confirm that this is another example of the same problem, which will be fixed.
